Sponsored by: Innova
Remote Start
Old Nov 3, 2007 | 12:54 AM
knash0727's Avatar
knash0727
Remote Start
Is there any remote start system for a diesel? It would have to delay for the glow plugs to heat up before it fires.
Old Nov 3, 2007 | 09:32 AM
FTE Trigger's Avatar
FTE Trigger
I know just about anything from DEi either has the functions already on it or offer it as a add-on. Same thing goes for Code Alarm (Audiovox) and Ungo (Clarion).
Old Nov 3, 2007 | 10:03 AM
black04lariat's Avatar
black04lariat
Yea. Not sure about other brands but I would assume they do. DEI has a wire that would need to be hooked up called a 'wait to start' wire for just this reason. Also, you may need another box which is called a 'tach signal generator'. When I was an installer, not very many diesels came in, but the one I did needed that 'tach signal generator' to get it to work properly. Not sure if it is for all.
Old Nov 4, 2007 | 06:47 AM
MattyNJ's Avatar
MattyNJ
I have a remote start on my deisel....its set to delay then start.
Old Nov 4, 2007 | 08:10 AM
knash0727's Avatar
knash0727
Thanks ya'll
Old Nov 4, 2007 | 08:14 AM
MattyNJ's Avatar
MattyNJ
Ill find out who makes it and post later...I think its cobra? works up to 1 mile away which is cool!
Old Nov 4, 2007 | 11:28 AM
riggz's Avatar
riggz
I'm guessing you are thinking of the Viper 5900SST. I just installed the same model in my 2004 6.0L.
To the OP, what truck are we talking about? I know the 6.0L & 6.4L super duties and maybe a few of the 7.3L have a tach wire that is ready to use just under the dash. It's installed so that a PTO may be installed in the future.
Old Nov 4, 2007 | 02:20 PM
knash0727's Avatar
knash0727
I have a 6.9 IDI Diesel. 1985 f250
Old Nov 4, 2007 | 08:18 PM
dsldandually's Avatar
dsldandually
Are you gonna have automatic starter fluid injection too???
Old Nov 4, 2007 | 10:44 PM
knash0727's Avatar
knash0727
what do you mean?
Old Nov 5, 2007 | 11:25 AM
USMC Diesel's Avatar
USMC Diesel
Last month I installed the factory remote start with the security system on my 06 diesel. The module with Tack inverter cost me $260.00 and took about 8 hours to install. It has a diesel timer built in I got it from http://www.powerstrokeshop.com/ and downloaded the instructions from http://www.gemsen.com/Ford/ Hope this helps
