3spd w/OD
Old Jun 26, 2000 | 07:34 PM
jlasater's Avatar
jlasater
3spd w/OD
I've been trying to find out info about the Warner T-85-N 3 speed + OD tranny that evidently was an option in the '71 F100 line. Basically, I need to know if one would be a drop-in for the plain 3spd in my truck now, and does it improve highway performance (lower rpm's) or does it give you lower gearing for towing/off-road work?
Finally, is this tranny as strong as the standard 3spd unit?
Old Sep 19, 2002 | 09:33 AM
turbogus's Avatar
turbogus
3spd w/OD
I've got the 3/sp OD trans in my '81 E-150. It's a stock unit and I believe it's called a RUG/RAB tranny referred to as a 4/spd Overdrive. Rather than a granny first gear it's conventional and the rpm's drop 1200 between 3rd and 4th (OD) No problems so far and it's over 20 years old.
Old Sep 19, 2002 | 10:12 AM
turbogus's Avatar
turbogus
3spd w/OD
