305/55r20 ???
Nov 2, 2007 | 08:32 PM
305/55r20 ???
Will these fit an 05 F250, stock height, on 9.5 rims with a 8X170 bolt pattern?
Nov 2, 2007 | 08:48 PM
what rim/offset?
Nov 3, 2007 | 10:42 AM
Nov 3, 2007 | 12:58 PM
Quote:
Originally Posted by arno
Just stock.
last time i checked the widest rim a f250 came from the factory with was 8".
Nov 3, 2007 | 03:34 PM
True, aftermarket rim, same #'s.
Nov 3, 2007 | 03:52 PM
IIRC they will rub without a lift, tire width is the problem. Also you are losing load capacity of the tires, OEM is 3640lb.
305/55R20 (33.4x12.4x20)
Nov 3, 2007 | 04:58 PM
help me out here, ima little slow today.
Nov 3, 2007 | 05:01 PM
i have toyo 305/50/R20 and they don't rub at all, only on a full left turn. Truck is in sig and gallery. They are aftermarket wheels as well.
Nov 3, 2007 | 06:02 PM
Quote:
Originally Posted by bruno6491
i have toyo 305/50/R20 and they don't rub at all, only on a full left turn . Truck is in sig and gallery. They are aftermarket wheels as well.
Well they either rub on a left turn or they do not rub at all! Which is it, do they rub or don't they? It cannot be both.
Nov 3, 2007 | 08:21 PM
What back spacing do you wheels have? Truck looks great and I am looking for the same setup. Where did you buy from?
Nov 6, 2007 | 04:48 PM
the tires only rub on a full lock to the left, which means i just take full lock turns to the right when parking. No problems and been running them for about 8k miles
Bruno
3054024 ,
30550r20 ,
30555r20 ,
brawn ,
duty ,
expedition ,
f250 ,
ford ,
incubus ,
oem ,
offset ,
rims ,
rub ,
super ,
wheels
