Electrical problem,,need answers!
Old Nov 2, 2007 | 06:17 PM
msb71's Avatar
msb71
This problem started a few weeks backs only slightly at first but is more persistant now. Here goes, sometimes it seems it is running soley off the alternator, for example today everything was going good , gauge was reading fine then I hit the button for the window , then my amp for the stereo stopped working, gauge was eractic , the tranny was shifting hard , engine revved a little while sitting at light, got worse as I drove on ,I was scared to turn it off, wanted to get home.when I do cut the truck off when it does this there is NO POWER at all, after a little time it will start up.
My ideas: maybe my MSD 6a box is going bad , it started shortly after installing it.OR?
I stopped halfway home disconnected the box from power and the harness to coil and just went with the coil , started right up ,no problem for half an hour on the road.
Anyone ever heard of this? gonna drive with the 6A disconnected to see if that is the problem or could it be something else?
Sorry for the long post
Mike
Old Nov 2, 2007 | 06:44 PM
Lou Braun's Avatar
Lou Braun
This sounds more like poor connections at one or both battery terminals. The connection could be bad or perhaps one of the battery cables is internally damaged.
For sarters I would clean each terminal and make sure the connection is solid. With good connections and a decent battery, all of your accessories and lights should work OK when the engine is off. This is easy to check.
Crummy electrical connections are common on older trucks and can cause some strange symptoms. If your MSD system worked OK in the past, it is probably not the cause of your problem.
Lou Braun
Old Nov 2, 2007 | 07:31 PM
msb71's Avatar
msb71
So I should check all my wiring then , sounds good to me, I'll give it a try. They work most of the time , but when it snaps off, things still work but I can tell something is not right, like it is starving for voltage.
Mike
Old Nov 2, 2007 | 10:24 PM
frederic's Avatar
frederic
Check the battery connections first, then make sure your ground strap between the engine and the frame hasn't rotted off. I had the exact same symptoms when my ground strap decided to fall off.
The alternator's ground is the engine block - and if that block isn't grounded the frame and the radiator support then you essentially have potential for many, many oddball electrical problems.
And the ground straps always rot off eventually - it's just a matter of time. They're bare braided wire so salt, water, etc, gets trapped in them and they rot faster than the frame/body.
Old Nov 3, 2007 | 08:06 AM
msb71's Avatar
msb71
Gonna try to get out to check the ground , but it has rained , so it'll have to wait til it gets dry outside.
Mike
Old Nov 3, 2007 | 10:37 AM
mhg's Avatar
mhg
after checking all the connections
the check the alt.
the truck is always running off of the alt.
the batt. is a storage unit
the only time it is used is to crank the truck
or run the acc. when the engine is off
check all the wires on the back of the alt. and then
get it load tested at a local AAP or eq.
these symptoms are possible with a weak alt.
Old Nov 5, 2007 | 04:38 PM
msb71's Avatar
msb71
Ok , went to the local Advance and had the alternator checked, it's final reading was 60.6 amps w/ the A/c running, whats the verdict ,is it enough amperage to have my stereo amp and ac and 6A box going?
I posted on friday and since unhooking the 6A box there has been no problems since, I drove for a couple hundred miles since Friday with no problems.
Mike
John-Oswego
Sep 30, 2019 01:04 PM
Cowcharge
1997 - 2003 F150
Sep 13, 2014 05:18 PM
mrz50
Feb 2, 2011 11:23 AM
1998F250
Electrical Systems/Wiring
Mar 15, 2005 12:29 AM
