More Brake Issues
Old Nov 4, 2007 | 04:21 PM
fullcircle's Avatar
fullcircle
Thanks for the help. I'll report back what fixes it.
Old Nov 4, 2007 | 10:32 PM
drz400gncc's Avatar
drz400gncc
i had this problem once. come to find out the self adjusters were not working on the rear brakes. after adjusting them manually it fixed the problem.
Old Nov 9, 2007 | 04:30 PM
fullcircle's Avatar
fullcircle
I have brakes now. Thanks for all the help.
After replacing the other caliper, installing yet another Master Cylinder (new NAPA MC for GAS engine (it has a bigger bore)) I decided to check the rear brake adjustment. The left rear was out of adjustment when I had just adjusted it two days ago. I took it apart and it turned out that the adjuster "puck" had fallen off, but the adjuster was still hitting both shoes but not correctly on one of them. The "puck" was in the bottom of the drum, undamaged. I cleaned and lubed the adjuster, reassembled, and re-adjusted, and the brakes are better than I can ever remember. All along, I think the problem was that the one wheel cylinder had to go to maximum travel which required continuous pedal travel.
Yet another time when I should have simply checked the simple stuff...first instead of last. Thanks again.
