Fog Light Wiring
Old Nov 2, 2007 | 02:02 PM
al_bundy's Avatar
al_bundy
Fog Light Wiring
I am thinking about putting some lights on the exterior of my truck for hunting season. The issue is that I want to be able to remove the lights when I am not using them. How could I get power to the lights, but still be able to control them from the cab? I could easily tap into the trailer/auxillary power connection, but then I can't control them from inside the cab.
Old Nov 2, 2007 | 09:42 PM
Franklin2's Avatar
Franklin2
Do you want official foglight wiring, and the lights will be mounted in the grille area? Or do you want something you are going to hold in your hand or mount up near the door?
Old Nov 2, 2007 | 11:11 PM
al_bundy's Avatar
al_bundy
The official fog light wiring looks complicated. My truck doesn't have the fog light integrated switch. I was thinking about something I could prop up from the truck bed to shine out over the cab.
Old Nov 3, 2007 | 12:33 PM
Franklin2's Avatar
Franklin2
Then I recommend you get a plug and wire it into the cigarette lighter socket. If you have a sliding rear window you could run the wire through that to the light, and then just unplug everything when you didn't use it.
Old Nov 3, 2007 | 08:20 PM
al_bundy's Avatar
al_bundy
I thought of the rear sliding window myself. Unfortunately, I don't have one! What I am thinking about doing is wiring into the trailer wiring, then using a magnet to control a reed switch on the outside of the window. That way I will be able to control it from inside.
