Sponsored by: Real Truck
Noise
Old Nov 2, 2007 | 05:34 AM
smyp's Avatar
smyp
Noise
I'm gonna try to post again.
I have a noise that shows up once I hit RR tracks or a pothole. Kinda sounds like a hub dragging. The noise stays until the truck is just about stopped. I took out the main gear in the hubs and the noise still comes back. I appreciate any help that I can get,
Mike
Old Nov 2, 2007 | 08:14 AM
redford's Avatar
redford
FTE Leadership Emeritus
Do you hear the noise when the hubs are locked?
Old Nov 2, 2007 | 09:44 AM
smyp's Avatar
smyp
Yes, I have heard with the hubs locked. I've tried knocking it out of gear too.
Old Nov 2, 2007 | 09:50 AM
rugermack's Avatar
rugermack
Are they the factory hubs or aftermarket ? Are all brake bolts tightened: caliper, caliper brakets ? Is it both sides or one side ? So, when you come to a stop, it sort of "resets itself" ?
Old Nov 2, 2007 | 12:12 PM
smyp's Avatar
smyp
Factory hubs. yep, all the brake associated parts are tight. As far as the sound/feel, it depends on which side af the truck your sittin in. You are 100% correct, once you slow to a stop the "noise/feel" resets itself.
Thanks
Old Nov 2, 2007 | 12:14 PM
redford's Avatar
redford
Does the noise change as you apply the brakes?
Old Nov 2, 2007 | 12:17 PM
rugermack's Avatar
rugermack
Somethings not right. When you finally figure this out I'd like to know. I'm waiting for someone else to chime in that has had this problem. I don't think a bearing hub would do that, but you never know.
Old Nov 2, 2007 | 12:30 PM
redford's Avatar
redford
If the noise happens when the hubs are locked, it isn't the hub bearings.
Old Nov 2, 2007 | 12:41 PM
rugermack's Avatar
rugermack
I didn't say it was the hub bearings, why would it only do it when he hits a bump ? That is the question.
Old Nov 2, 2007 | 01:45 PM
redford's Avatar
redford
Sorry, didn't mean to make it sound like you said it was the hub bearings rugermack, just making a general statement.
I've seen disc brakes do this (make noise when hitting a bump) when the pads get worn down a bit. It should change or even stop if the brakes are applied if this is the case. Not a serious issue, but annoying.
Otherwise, the front axle U-joints may have a problem.
Old Nov 2, 2007 | 01:52 PM
rugermack's Avatar
rugermack
That's O.K., just seems weird that it only happens when he hits a bump.
Old Nov 2, 2007 | 06:16 PM
smyp's Avatar
smyp
I've tried hitting the brakes and it makes no change in the noise. I'm at my wits end.
Thanks to all for your help,
Mike
Old Nov 2, 2007 | 08:10 PM
redford's Avatar
redford
I'd take a close look at your front axle u-joints, if not that then maybe the axle bearings?
superglide04
Mar 18, 2014 09:02 PM
tjc transport
Jan 8, 2014 06:55 PM
Greedy River
20
Jan 24, 2011 06:17 PM
ampslw
Jan 20, 2011 02:51 PM
Erik Sink
29
Sep 4, 2008 05:32 PM
