took a drive to a body shop about an hour away to dig through his bone yard. scored front and rear sway bars off a 78/79 2wd camper special. was able to get everything except the brackets that connect the swaybars to the front I-beams. Anyone know where I can order just those brackets from? not going to have much time to dig through the salvage yards anymore (baby on the way) so if I can order them online or through ford that would be great.
You are in luck, the brackets are still available from Ford, as are the sway bar end bushing kits (you don't want to install the old cracked bushings, do you?).
2-D5TZ5C499A .. Front Sway Bar Bracket-to I Beam (fits all F100/350's 1975/79).
NOTE: The brackets only (not the sway bar) were also used on 1975/91 Econolines.
FTE sponsor DIRECTFORDPARTS (DFP) shows a list price of $39.67 each / FTE member price $28.04 each.
2-D8TZ5A486A .. Front Sway Bar End Bushing Kit (fits all F100/350's 1973/79)
DFP shows a list price of $10.55 each / FTE member price $7.46 each.
I can't seem to find the full sponsor list to get to DEP. I like to find a picture of the "I" beam brackets to see if they work on A.I.M. lowered beams.
