FLYWHEEL RESURFACING
Old Oct 1, 2002 | 06:46 AM
Stephens's Avatar
Stephens
The clutch in my 88 +200K miles, 5 speed needs replacing. It works OK around town and is smooth, but when I pull a heavy load, like pulling my boat out of the water, it slips and the throwout bearing chatters. I'm planning to get a clutch kit, take off work Friday and do it. I'll rent a transmission jack and repalce some seals (rear main, trans... while I'm at it). I'd like to have my flywheel resurfaced, but I'll be without transportation once I disassemble. I was advised by a fairly knowledgabale mechanic, to not worry about that because most of them stay smooth unless, its worn down too much and gets gouged up. I'd hate to put a new clutch in and have vibration. Anyone have advice on this?
Old Oct 1, 2002 | 08:33 AM
whittey's Avatar
whittey
Just do it
Seriously, I can't see the point in going all the way to the clutch and not spending the $10 to get the flywheel resurfaced (sorta like why get all the way there and not change the rear main seal, but I see you are doing that). Call in some friends for a ride to your favorite machine shop (or wherever else does it).
-=Whittey=-
Old Oct 2, 2002 | 07:14 AM
Stephens's Avatar
Stephens
Thanks Whittey. I appreciate the advice. I was feeling that way too. I'd rather go through a little extra trouble getting to the machine shop than alot of trouble later because of vibration in the clutch.
Thanks again.
Old Oct 2, 2002 | 05:04 PM
82F100SWB's Avatar
82F100SWB
AbandonedBronco
1978 - 1996 Big Bronco
Jan 13, 2013 01:21 AM
Eallend7
Dec 12, 2012 05:56 AM
kooper909
15
Apr 11, 2008 09:59 AM
Varnish
Apr 27, 2002 01:31 PM
