timing troubles
Old Oct 7, 2002 | 12:09 AM
cw50must's Avatar
cw50must
timing troubles
Can someone describe the timing mark for me? All I found was a notch that was fairly wide on the pulley. It wasn't like a little line etched in the metal it was all the way through. I put a touch of white paint on it so I could see it with the light. I pulled the spout and went to check it. It is nowhere near where the degree markers are. I don't think the truck would even run if it were that far off. So should I be looking for some other mark, because I searched the whole thing very long and carefully and don't see any other mark at all.
Old Oct 7, 2002 | 02:45 AM
heathdaily's Avatar
heathdaily
timing troubles
There's an excellent description under "TDC 3oo 6" topic #1943 By stractor. A search should turn it up no problem. By the way that 3oo is spelled with O's not zeros.
Old Oct 7, 2002 | 07:51 PM
cw50must's Avatar
cw50must
timing troubles
Thank you sir, that's exactly what I needed. Looks like that was the wrong notch. I will have to get under there with a real good light and search harder.
Old Oct 7, 2002 | 10:22 PM
str8six's Avatar
str8six
timing troubles
