HOTTTT!!!!!!
Old Oct 8, 2002 | 05:43 PM
knocturnal's Avatar
knocturnal
Post HOTTTT!!!!!!
fuel injected 4.9 and i love it to death but ever since new <10 years ago> it would idle and get very hot and im talkin 220 230 hot but then when you get it goin it cools right down to about 190 and stays even in the winter my dad says its done that eversince it was bought but i just figured you guys could gimme some info\tips
thanks
Old Oct 8, 2002 | 07:03 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
HOTTTT!!!!!!
my 90 f150 300 I6 had the same problem. whenever i looked into it i found the thermostat was rusted completely shut, and my water pump went bad (since no water flow). seems the previous owner of my truck neglected to flush the radiator periodically. even though no water would flow through the motor, the thing ran alright air cooled(not recomended)
J.R.
90' f150 xlt lariat
4x4 5spd 3" body lift
33" x 12.5 tires
Old Oct 8, 2002 | 07:18 PM
knocturnal's Avatar
knocturnal
HOTTTT!!!!!!
so i should just look into my thermostat?
Old Oct 8, 2002 | 07:41 PM
jrs_big_ford_f150
HOTTTT!!!!!!
it wouldn't hurt to check it. the thermostat is behind the upper hose connection to the block. also check the color of your coolant. mine was brown which helped me find the rusty thermostat. whenever you get your themostat out put it in a pot of boiling water and see if it opens. if it does not then your problem is probalbly a blocked hose or fitting. although its alongshot, check the water pump too. if it siezed then you will get no water flow, and more expensive to fix than a thermostsat.
J.R.
Old Oct 8, 2002 | 07:45 PM
knocturnal's Avatar
knocturnal
HOTTTT!!!!!!
thanks jr
Old Oct 8, 2002 | 08:21 PM
jrs_big_ford_f150
HOTTTT!!!!!!
anytime knocturnal
Old Oct 9, 2002 | 07:21 AM
whittey's Avatar
whittey
HOTTTT!!!!!!
