help for a friend
Old Oct 31, 2007 | 07:46 PM
01redcrew's Avatar
01redcrew
help for a friend
A buddy of mine has a late 99 f350 4x4 in today he was going to pull out of his drive way and his truck acted like it was in 4low but the shifter was in 2h and than he tried to put the truck in 4low on the shifter and that worked than he tried to take it back to 2h and now its stuck in neutral. Has anyone had this problem before
thanks for any help for him
Old Oct 31, 2007 | 08:09 PM
medhvac's Avatar
medhvac
if it was in 4low the 4x4 light would of been on on the dash board!
Old Oct 31, 2007 | 08:40 PM
01redcrew's Avatar
01redcrew
nope he said the late wasnt on, and also he said when he tried that he heard some grinding
Old Oct 31, 2007 | 09:09 PM
hosemandc's Avatar
hosemandc
Is he putting it in nuetral and a dead stop when shifting in and out on 4-low?
Old Oct 31, 2007 | 09:13 PM
01redcrew's Avatar
01redcrew
yep and even tried it with the truck turned off
Old Oct 31, 2007 | 09:42 PM
greedy737's Avatar
greedy737
You have to press the brake too
Old Nov 1, 2007 | 07:31 AM
Kwikkordead's Avatar
Kwikkordead
99.5 4x4 transfer cases had a very poor design in the main shaft. No lube was provided for the shift fork and it grinds itself up.
Mine gave out on the top of Mt. Rainier National Park and it cost me $550.00 to get towed home. The parts to fix it cost me $450.00.
Seems they come in waves. I just posted this thread somewhere else today too.
Here's the pictures of the inside and the differences between the original and the updated design.
Originally Posted by Kwikkordead
Ok, these are the two main shafts side by side. Notice that the new one has an oiling galley for lubricating the shift fork.
Here you can see the new shift fork and the 180 degree plastic "bearings". They snap into the notches on the new shift fork. And the new slider with the oil galley sitting next to the old one without the oil galley.
Assembled and ready to close up.
All done.
Old Nov 4, 2007 | 11:56 AM
01redcrew's Avatar
01redcrew
hey thanks for that bit of info ill let him know that
Old Nov 4, 2007 | 01:34 PM
clintbonnie's Avatar
clintbonnie
Does the early 99's have the same lack of lub problem?
Old Nov 4, 2007 | 07:37 PM
Kwikkordead
Probably. I would remove the filler plug and attempt to see what the shift fork looks like if I were you.
Let me repeat what I said about this failure after I got the truck back home.
I had no warning sounds whatsoever. No rattles, funny noises, hard shifting, nothing.
I was simply coasting back down the mountain at about 1200 rpm and the whole thing simply dropped to neutral. I had to hitchhike back up to the lodge and phone a tow truck from the middle of the park and pay through the nose to get back home.
I repeat, no warning sounds at all. It just quit and that was it.
