Modular V10 (6.8l)
engine and battery on even when
Old Oct 31, 2007 | 03:20 PM
myfirengine21's Avatar
myfirengine21
the key is off and the engine and power is still on,,i have replaced the ignition switch, still doing it could there be a relay or battery switch still engaged, this is on a motorhome 1992 pace arrow
Old Oct 31, 2007 | 04:40 PM
BareBones's Avatar
BareBones
You must be right, its probably a frozen relay, though I guess a shorted wire might have the same effect. Of course you probably would have smelled a shorted wire though. Doesn't your fuse panel have some kind of fuse/relay description on the inside of the cover panel?
Old Nov 1, 2007 | 08:04 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
V10's didn't exist in 1992 - what engine is it?
