LT or P ????
Old Nov 1, 2007 | 01:25 PM
MBBFord's Avatar
MBBFord
Originally Posted by BigBlueMacDaddy
I've been following this thread, and gotten quite a bit of info. I have a Black 07 XL, eight foot body, and wanted more than the plain steel wheels, even the wife doesn't like them! I bought a set of Lincoln wheels (18", and it already has a Lincoln grille!)) and have been itching to put some good tires under the truck. To keep the speedo somewhat accurate, I have been looking at keeping the width the same, and dropping the aspect from 70 to 65. I am surprised that the ride deteriorated when you made the switch from Hankooks to Michelins, I had expected it to be at least the same, if not better. My truck hauls usually only me, and the wife, maybe 200 pounds of cargo, max. I was thinking of going to a better riding tire, as I still have my 77 F350 for dirty or heavy work. (It was just getting TOO UGLY!) With all the variables you guys have mentioned, maybe I should rethink going up in size from 17 to 18, and get some new rims, and keep the Hankooks. Any thinking on anyone's part? Oh yes, has anyone had trouble with the TPMS damage as to mounting, and remounting the tires?
I'd stay with 17" wheels. you have more options, and tires are cheaper.
The only problem with the TPMS is if the person taking the bead of the tire off isn't paying attention and does it right where the valve stem it, he could break it. Other than that, nothing should go wrong. I'd mounted and dismounted tires on wheels that had the TPMS, and nothing went wrong.
Old Nov 2, 2007 | 01:22 AM
hiall10000's Avatar
hiall10000
I think LT tires will be better.
Old Nov 2, 2007 | 11:59 AM
berry1234's Avatar
berry1234
You can argue this all day. The ply makes a big difference in harshness. I had a set of Pro Comp 10 plys on my 05 and it rode like a tank. Bounced, banged, rattled your teeth loose. Tried some passenger tires and it was much much better. Problem is they are rated for a lot of weight and the abuse I give them.
I would stick with a LT tire but not a 10 ply.
Old Nov 2, 2007 | 12:29 PM
Peter94's Avatar
Peter94
Yeah, a 10 Ply is what they run on F350's and such. I think the max you should go on a 1/2 ton would be a 6 ply. Unless you are doing something really abusive to your truck.
Dont get me wrong, i'd have a harsh ride in exchange for more carrying capacity any day, but there is a certain point where you will dangerously overload your truck before you have any effect on the tires.
Old Nov 2, 2007 | 12:50 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
it's a truck...not a Cadillac
but yeah, 10 ply is kinda ridiculous for a 1/2 ton unless they're mud tires
Old Nov 2, 2007 | 04:56 PM
f150dude05's Avatar
f150dude05
I just put a set of LT285/55/20 Michelin LTX AT2 on. I notice a much harsher ride, so I will adjust the air pressure some. I have always felt better with a LT tire . I have had rocks off gravel roads punture P tires. The Pirelli Scorpion ATR P-rated tires that came on my truck were terrible in mud and snow.
Old Nov 2, 2007 | 06:58 PM
MBBFord's Avatar
MBBFord
Your saying 6 ply tires are the MOST you should have on a 1/2 ton truck?
They don't make 4 ply tires for these trucks, and the cheap O tires are 6 plys.
I think 6 ply would be the least if the truck wasn't used as a truck(no towing or anything), but a 8 ply would be a good match for these trucks when it is used as a truck(some towing, hauling, every now and then).
I just got a set of 10 ply hankook m/ts, and they are just a little stiffer/harsher than the stock 6 ply bfg(all season tires). The new tires are a lot better in side wall stability(truck lean) when driving and towing.
Old Nov 2, 2007 | 11:55 PM
BrianA's Avatar
BrianA
I guess I'm odd man out.
I just put my third set of Hankooks on a few weeks back.
http://www.hankooktireusa.com/produc...il.asp?pid=330
255/65-17
They are P Metric and do great for my use.
I got 55,000 miles each out of the first two sets (and could have easily made 60,000+ miles). A good tire for the money.
IMO, unless you are doing heavy hauling or towing, it's all that is needed on an F150.
Old Nov 3, 2007 | 12:16 AM
Peter94's Avatar
Peter94
I think 6 ply is the most a 1/2 ton would need. Say a 275 65 18 Dueller Revo has a 114T rating, meaning it can carry 2640LBS X 4 Tires= 10,560 LBS
That is practically twice the wieght of the truck. I think the F150 GVWR is around 6,000? say you overload your truck by 2,000 lbs, you are still not overloading P rated tires.
Even a load C on tire rack.com only has a weight rating of 2561 lbs.
Lets jump up to a 10 ply. The Load E firestone transforce has a load index of 123, which is equivalent to 3472 lbs x 4 tires = 13,888 lbs. Not necessary for a 1/2 ton truck. With radial tires a 10 ply does not mean it has 10 different ply's of material. It means its strenght is equivalent to a bias ply tire that has 10 plys, even though the radial tire might only be using 5 ply's.
None the less, I still like to have at least a load C on my trucks, but that is my choice. They dont seem to have as much "radial bulge' to them.
Too many people think that p rated tires are junk, when they are really not.
scameron7
2009 - 2014 F150
17
Dec 2, 2012 06:45 AM
Bonesbike
Jun 7, 2012 06:10 PM
787fordracing
2004 - 2008 F150
Jan 20, 2011 07:21 PM
SteveVFX4
2004 - 2008 F150
Nov 15, 2007 09:12 AM
K.O-T.O
2004 - 2008 F150
Oct 2, 2007 12:38 PM
