A/C question
Old Oct 31, 2007 | 05:52 AM
V10man's Avatar
V10man
A/C question
When the a/c is in Max setting, the air will sometimes switch from the a/c vents to the defrost vent. I'm guessing it's a vaccum issue somewhere because when you get on the throttle it dose it. It works fine in reg a/c mode. Any tips on where to start looking? Thanks.
Old Oct 31, 2007 | 05:59 AM
92F150Flare's Avatar
92F150Flare
First place to check is the "coffee can"......it's been known to rust out on the bottom where it can't be seen. The line going from it through the firewall is the culprit sometimes too. Others would be the lines under the dash.
Hard to find sometimes.....vacuum lines get brittle and crack right at the fitting and the crack isn't always big enough to see. I always move them a little with my fingers. If cracked they will usually break off then.
Almost as bad as wiring issues.
Good Luck
Bob
Old Oct 31, 2007 | 07:51 AM
subford's Avatar
subford
Look for a broken White vacuum line on top of the A/C box under the hood.
You may not have a vacuum tank if you do it may look like a round ball.
The Coffee Can is for the emission system.
