Modular V10 (6.8l)
High engine rev at start up
Old Oct 30, 2007 | 04:07 PM
UncleD's Avatar
UncleD
'99 V10 in F350
Doesn't happen every time. But after it has set for a few days, or over night, as soon as it starts it will rev to about 2-3k, then drop to an idle. This happens pretty quick, in less than a second. Any ideas?
Old Oct 30, 2007 | 05:38 PM
ameinig's Avatar
ameinig
Mine has started that recently also. 99 F250 v10 4wd 5sp 168k. Curious to find out what is causing this. Can't be good to immediately rev a cold motor.
Old Oct 30, 2007 | 07:33 PM
super 6.8's Avatar
super 6.8
That was a beef I had with my 99. On cold start up it would rev to 1800-2000 and then settle down to 1200-1300 right away. It just bugged me to see it rev so high on cold start. It did it from day one and it never seemed to hurt it. I sold the truck to a friend who has it over 100,000 miles and it still uses the same 1/2 to 3/4 quart between oil changes.
Old Oct 31, 2007 | 07:32 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'd check for vacuum leaks, and then change the IAC.
My '01 revs up to somewhere around 1500-2000 or so (haven't watched it in a LONG time), and then drops right back down.
It revs up enough to torque the entire truck over
Old Oct 31, 2007 | 09:24 AM
UncleD's Avatar
UncleD
Yes, that's my worry also Krewat. At times I'm afraid it's going to flip over on its side from all the torque
Old Oct 31, 2007 | 12:44 PM
mackstruck's Avatar
mackstruck
I have a 2002 and it has done that same thing since day one. It does it every two to three weeks. Its does it on hot and cold days. It usually happens after the truck has sat for a few days.
Old Oct 31, 2007 | 05:02 PM
twayneb's Avatar
twayneb
Same with my 2000,from day one new, was told by 2 different dealers it is normal.
Old Oct 31, 2007 | 06:32 PM
krewat's Avatar
krewat
My '97 Cougar 4.6L does it too - but my '96 T-bird 4.6L (same motor and PCM) didn't.
Go figure.
Old Nov 1, 2007 | 07:35 AM
Big Orn's Avatar
Big Orn
Originally Posted by UncleD
'99 V10 in F350
Mine has done it since new - still does it...about 2200 RPMs.
'99 model here.
I don't know whether it's normal or not, but it hasn't seemed to hurt anything. I do change the oil at 3K and use Castrol GTX 5w30 - no problems with tapping or knocking. Over 130K miles.
Old Nov 1, 2007 | 09:38 AM
UncleD's Avatar
UncleD
Sounds like it's a common thing. That's good to know. I won't worry about it anymore.
Thanks guys.
Old Nov 1, 2007 | 10:24 AM
marcussen's Avatar
marcussen
My 1995 F350 with a 460 always reved up when started then settled down, My '08 does the same thing I never thought about it.
Old Nov 1, 2007 | 04:50 PM
UncleD's Avatar
UncleD
If it didn't do it so quickly, I wouldn't have worried about it either. But it's like starting it with the gas peddle pressed about half way down, then letting off as soon as it hits.
But it seems like I don't have the only one that does it, and the others haven't had any damage, so it must be a normal thing
Old Nov 1, 2007 | 05:17 PM
Big Orn's Avatar
Big Orn
Yep - you get used to it.
