electrical outlet questions
Old Nov 2, 2007 | 11:59 AM
  #46
MisterCMK's Avatar
MisterCMK
huh?
I posted the reference in the NEC that goes over all of this
Old Nov 2, 2007 | 03:18 PM
  #47
alchymist's Avatar
alchymist
"Mifflin Clay"
Originally Posted by MisterCMK
A 15amp outlet is perfectly fine on a 20amp circuit PROVIDED that it is not the ONLY outlet on that circuit.
He He..at the risk of killing a few more megabytes and 30 more posts, I gotta ask:
What is the electrical difference with a circuit with a 20 amp breaker, #12 wire, and one 15 amp receptacle and a circuit with a 20 amp breaker, #12 wire, a 15 amp receptacle and a 20 amp receptacle when the 20 amp receptacle has nothing plugged into it? Note that I'm not asking what the NEC says about it, I'm asking what the electrical difference is.......
Old Nov 2, 2007 | 06:51 PM
  #48
jroehl's Avatar
jroehl
Electrically, the differences are that one circuit has one outlet, the other has two, and their configurations are different. The first, however, is not allowed by the latest version(s?) of the NEC. Most people never even install a single outlet on any 120V circuit, as duplex receptacles (which count as 2 outlets in the NEC) are generally cheaper and more easily obtained).
Having spent some time in Electrical Engineering, there are quite a few things in the NEC that are real head scratchers, as they make no sense in terms of electrical performance. But, somewhere, one time, there may have been a problem, so code is written to try to prevent that problem. It's kind of like having a guard rail next to a cliff: do you put the guard rail AT the cliff, a foot back, three feet? What if there's a sharp turn in a highway right before that--50 feet might be better in that case...
Jason
Old Nov 2, 2007 | 08:26 PM
  #49
alchymist's Avatar
alchymist
"Mifflin Clay"
Jason
Point taken about Why, but - re-read my post -
1) I specifically asked NOT about NEC, but "electrically"
2) I said "receptacle", not outlet, which in general means a " duplex outlet"
3) Granted, the one circuit has 2 receptacles, the other one, but the 20 amp is "UNUSED". Would it make a difference if I said one had 2 of the 15 amp outlets, one unused?
From an electron's point of view, the circuits are identical.
On with the discussion - how I love playing devil's advocate......
Old Nov 5, 2007 | 05:28 PM
  #50
85e150's Avatar
85e150
OK, 20A circuit, 12 ga wire. Multiple 20A receptacles. Two 15A switchs to single light bulbs with 12ga wire also on the circuit. Based on what was quoted above regarding 15A items on 20A circuits, it seems like this should be OK.
And yes, it's polarized and grounded all the way.
Old Nov 5, 2007 | 06:10 PM
  #51
jroehl's Avatar
jroehl
That's perfectly acceptable AFAIK, as long as those switches aren't switching all those 20A receps.
Jason
Old Nov 5, 2007 | 11:21 PM
  #52
85e150's Avatar
85e150
Thanks, no not switching the receptacles. Using 20A rated switches for the "half hot" receptacles. Total overkill, methinks.
Old Nov 5, 2007 | 11:47 PM
  #53
sierraben's Avatar
sierraben
Over kill is when you plug in a high wattage/amperage appliance/device rated more than the receptacle can handle.
I think 20amp twist lock receptacles should be the minimum standard. (jk)
Racerguy
Jul 4, 2011 08:19 AM
scottie2hottie
29
Sep 7, 2008 04:14 PM
ag-ford-4x4
13
Dec 22, 2006 09:56 PM
924x2150
52
Jan 10, 2006 06:53 AM
