Auto down windows
No! You only need three one touch down modules from a 90s Town Car (or simular) one for each window, I geuss if you were really keen you could fit one to each of the rear vent windows as well
Here is a wiring schematic for a one touch down module as you can see you only have to splice into the existing wiring in the door, power can be found at the switch, cut into the window motor wires and then run in a ground wire, I wouldn't recommend using the door sheet metal as a ground but thread a wire through to the door pillar.
Not sure how much these modules are from the dealer but I believe somewhere in the 40 - 50 dollar range.
Regards
Dereck
Here's an old thread about it. https://www.ford-trucks.com/forums/2...ight=auto+down
Here's where you get a module for it. Disregard that it is marketed for the 05+ Mustang. It works in our trucks as well. http://www.webelectricproducts.com/products.htm
Here's where you get a module for it. Disregard that it is marketed for the 05+ Mustang. It works in our trucks as well. http://www.webelectricproducts.com/products.htm[/QUOTE]
I could use this module and the one touch down window switch on the rest of the doors like the one in the picture.
I never did get around to buying the modules...hmm...got me thinking again!
BTW, with this module you don't need a new switch. I think you just hold the existing switch down for a couple seconds and then it becomes an auto down. And for some reason I think you can wire it in reverse so that you get auto-up as well.
I geuss I have been talking to myself all the way through this thread
Regards
Dereck
Maybe it was your British accent?
Only thing I added was the use of a module that isn't Town Car specific and may be cheaper.
I said use the Town Car module because I know Town Cars and I know it will work it should also be readily available through the dealers or at the boneyards, I suspect the same module was used in the Crown Vic, Grand Marquis and most probably three quarters of the Ford range at the time.
Here you go OEM Ford One Touch Down Modules only 30 bucks shipping included
http://www.ponyperformance.com/specials2.html
Regards
Dereck
The hardest thing was finding a place to mount the module itself. Hmm...maybe my Excursion needs this mod.
In the Cobra...you tap the switch button quickly and release for auto-down...if you hold the switch more than momentarily it stops when you release.
It seems you are beyond help in this thread, I tell you four times you DO NOT NEED NEW SWITCHES, I give you a wiring diagram, I give you a link to cheap OEM Ford one touch down modules, what more do you want?
This is the last time I tell you;
FITTING AN OEM FORD ONE TOUCH DOWN MODULE TO EACH WINDOW WILL MAKE ALL EXISTING WINDOW SWITCHES ACT EXACTLY LIKE THE ONE MARKED "AUTO" ON THE MASTER SWICTH PANEL.
YOU PUSH THE SWITCH MOMENTARILY AND THE WINDOW WILL GO ALL THE WAY DOWN, YOU PUSH AND HOLD THE SWITCH THEN WHEN YOU RELEASE IT THE WINDOW WILL STOP.
Is that clear enough?
Regards
Dereck
