Manual transmission flush?
Now my question is, I know that metal went somewhere. The drain magnet was covered with sludge and filings. Is there a good flush you can put through a standard to hopefully wash more of the filings out? I was going to just drain the fluid once every couple of weeks for a few times and see what that did. What product do you suggest? What is the best means of application?
I just did the plug job on my M50D, (check my gallery), my shift forks were still good, I tried the metal freeze plugs but my holes were different sizes, so I went with OEM plugs from a Ford dealer and put copper RTV sealant on. No leakage. My gasket was still good though, if I didn't have to wait 2 weeks for the gasket I would have done it though. It was a fun job and the peace of mind by having this done and (saving a couple hundred) is worth alot.
I don't know much about flushing a manual transmission. Whatever you use it should be nice to brass, because there are some brass and plastic parts, so no strong cleaners that could harm stuff. I am wondering to a reply as well. I will enjoy the chance to learn more.
