Start, run problem 1985 150
Old Oct 29, 2007 | 09:04 AM
1985yardtruck's Avatar
1985yardtruck
When I turn the key to start, dash warnings are on, engine turns and fires, I can give it gas.... but when the key snaps back to run position, engine quits.https://www.ford-trucks.com/forums/n...ewthread&f=37# Truck has a new starter, distributor cap, plugs and wires.
Old Oct 29, 2007 | 04:18 PM
thestraycatmjf's Avatar
thestraycatmjf
sounds like you have a wie issue with a contact, i had one that i couldnt allow the cylinder for the key to turn all the way to run, there was a wire that corroded and when the barrel returns to run the connection is lost.
Old Oct 29, 2007 | 04:23 PM
Franklin2's Avatar
Franklin2
You can check the voltage on the coil + to make sure, but it sounds like a ignition switch problem, or the resistance wire is burnt out in the ignition switch wiring. The ignition switch is located on top of the steering column, underneath the dash.
Old Oct 30, 2007 | 11:53 AM
1985yardtruck
I checked coil, that seemed fine. I dropped the steering column, took off the ignition switch and cleaned the contacts.... somewhat grimed up. Other than a little binding of the rod, which I can hit it with some wd-40, the switch now functions as it should. Keep our fingers crossed. Thanks for the replys guys.
Old Oct 30, 2007 | 11:58 AM
thestraycatmjf
hey not a problem, glad to help, i will say though if there was corrosin on the ends of the contacts headed twords the wires, you may wanna look at replacing it in a year, depends on how far it was creepin down
