New F250 with a 5.4 gas
#47
Originally Posted by pathenry
brand new 06 f250sd. start problems,(approx 4000 miles)fixed.3 bad fuel injectors.fuel tank venting problems(not cap) caused engine lite. burns 1qt. mobil1 5w20 every 1000 miles. ived owened nothing but fords and im in my 50's. i think dayooper might be right.
#48
![Hijacked](images/smilies2/sign0101.gif)
![Off Topic](images/smilies2/sign0006.gif)
My opinion, yes it is. It's the same drivetrain as my 2007 F-250 except for the rear gears (I have a 3.73 LS), so I speak from direct experience.
I tow up to the rated limit of the truck
![Really Cool](images/smilies2/coolgleamA.gif)
The truck has not given me any problems and has never been back to a Ford dealer for warranty work.
I love my truck.
![Okay!](images/smilies2/thumb.gif)
#49
Originally Posted by redford
I second that! The 29 gallon tank in the short bed sucks when you're towing. Seems like I have to pull over more for fuel than I do pee breaks (unless the wife is with me, then all bets are off.)
As you stated RedFord, I LOVE this Super Duty!!
![Smilie](images/smilies/happy0161.gif)
#50
Originally Posted by Gregs69GTO
My Super Cab Long bed 99 is not as easy to get around tight areas as your short bed is, but my Long Bed has a 38 Gallon Fuel tank. I could see how one could go through a smaller tank quickly when towing.
#51
The 5.4L is not a problem prone engine. It is not underpowered. It puts out more horsepower than a 460 did. Most of the guys who are trying to recommend against a 5.4L have probably never towed with a 3V 5.4L Super Duty. I do on a regular basis.
I have a 2007 5.4L with the automatic and a 3.73 differential. As long as you're towing under 10,000 pounds you'll be fine. I often tow 9000 pounds easily. You won't win any drag races, but it'll easily get the job done. If I was getting another I would opt for the 4.10 gears.
If your towing load goes above 10,000 regularly then get a V-10 or a PSD.
As for mileage. I average 15 MPG mixed driving. Straight hiway I see 16-18 MPG depending on conitions. Straight city....well, it sucks.
Towing the trailer pictured, I get 10-11 MPG empty (it's about 3500 unloaded). The mileage goes down as the weight goes up.
When towing with a 5.4, put the transmission in TOW/HAUL mode, stick it in drive and let it work. A lot of guys get worried the engine winds out too much, but it's supposed to.......just relax and let it do it's thing.
TIA for ther infomative posts-
#52
Having both V8 and ten as you can see in another post. My co is getting 3 new F350-450 dually dumps
We have the V10 now and a v8 also. The v8 gets 3 MPG better than v10 !!! Empty!!! Like 10 MPG (the dump beds r heavy and the V10 get 7 empty on a good day empty and with you hauling only 1 a month or so . go for the v8 .
#53
#54
#55
Originally Posted by del_allen1957
I agree with the gentlemen that started this post.
I don't tow alot, however when I do this motor will get it done.
We pull a 10,000 lb travel trailer with this little 5.4.
If I towed this trailer every day I would have a diesel.
I've had 4 trucks with the 5.4 and I'll buy another.
I'll take the 1-2 MPG hit for the improved performance, even though I would call it occasional towing. As I've stated in other threads, once that loaded weight goes over 8-9K it's time for something bigger than the 5.4, be it V10 or PSD. JMHO, and YMMV.
#57
i had a 99 w/the 5.4. The only problem I encountered with it was the front cylinders would ground out if the truck sat for a while outside in the rainy seasons. the rubbers on the coil packs allowed some water to leak in and ground the cylinders. i found this out after about a $100 repair bill from my local shop. i didn't drive it a whole lot, but any time i did it would be hooked up to a loaded trailer. it towed fine on the flats but wouldn't do much in the hills. i just bought a psd to replace it- but then comes the trans issues with them. the psd gets better mileage and a lot more power, but fuel costs more and they cost more to maintain. they are also noisy. the 5.4 was really quiet. if you're not gonna tow a heavy load a lot, the 5.4 worked fine. you just have to get used to it downshifting and revving.
#58
I love my truck, it's only a 2v 5.4 and it pulls great, just doesn't have a lot of passing power (the main time I wish I had the money to have gotten a diesel)! A lot of times when we go racing, we take this one lane road most of the way, so we do a lot of passing and anything over 75 - 80 mph and I can't even floor it from behind the person in front of me to try and get by them, I just kind of stay even with them and that's in drive! I have to like get a running start on 'em and go by them with mph to pass, all the other guys laugh their asses off at me cuz they're just sittin there havin no problems with their diesels and i'm like ****!!! One of the guys was waitin for me to shoot out to pass before him and I just looked at him like dude, i'm floored and i'm not gaining, just go by, granted, this was at 90 mph, the guys I hang out with are a little nutty, a couple of weeks ago about 15 of us had just passed a car and were doin almost 100mph (hit my speed limiter for the first time tryin to keep up with them which looked to be about 98 mph) and flew by a state trooper with someone pulled over, you should've seen the look on his face, he was like WTF!!!!!!
#59
I weighed over the options heavily when i bought my truck, i thot about my use and cost and options ..everything..
I tow a 24' travel trailer .. prob about 6k
i tow a 14' boat.. prob 1.5k
i also have towed both at the same time (triple) .... 7.5-8k
(pretty much only in the summer months maybe a dozen times a year)
i also tow a 16' car hauler flatbed trailer, its usually full of firewood,or hay, or construction materials. the trailer is rated for 10k
(only a few times a year)
i use my truck as a daily driver, i've owned it for a little over a year now and have put 20k miles on it.... no problems. ( its great for hauling the family i like that fact that i can put 6 people in it if i had to and i have on occasion)
i fix up my truck because i like doing that and i want the most out of my vehicle i cant get.
i avg 13 mpg running around town, and i sure as hell dont "granny it"
best ive got on all hwy miles was 16mpg
when towing the above items best was 10-12mpg , worst was 7-8 mpg headwind and hills.
if i really want i can keep up with traffic on the interstate towing my camper @ 75+mph, it wont be in overdrive and it will be pushing 2500 to 3000 rpm and prob 8-9 mpg ... but it can do it...but its not like im doing that everyday either.
when I'am pulling steep mountain passes with that camper i have no issues and i dont think that 65mph is "creeping" up them even if i am at 3000-3500 rpm
If i was towing over 10k all the time i can undertstand the need for a diesel.... and then there are those that just "want it"
(i can beat most diesel's off the line anyway)
anyway just my $0.02
#60
I have a 06 Screw 5.4 f-150 that I have pulled an 8K toy hauler without any problems other than up hill and on windy days. With the 150, I definitely know the trailer is there. Picked up a 08 6.4 last weekend to handle the towing in the future. I would recommend against the 5.4 based on my experience with the 150. The engine was OK for flat towing but is somewhat "punky" going up moderate to steep hills. (Don't know if that is reflective of the 5.4 or the 4 speed automatic), You add the weight of the 250 to that and I think it would struggle even more. I do like the 5.4 and plan to keep it but not for any significant towing. Just my 2cents.
