Which C4 is best?
Old Oct 28, 2007 | 09:06 PM
CharlieLed's Avatar
CharlieLed
Which C4 is best?
Yeah I know it's a loaded question but I just bought a 69-70 351W engine this weekend for my 54 F100 and it came with a C9ZP C4 trans bolted to it. Trans code says it's from a 69 Mustang...my question is about the case, is the steel case better or worse than the aluminum? I am looking at rebuilding the trans for the truck but if it's a turkey then I will get another. Thanks...
Old Oct 28, 2007 | 09:20 PM
havi's Avatar
havi
I'll have the Roast Duck
steel case C4? It's not a FMX?
Old Oct 28, 2007 | 09:53 PM
CharlieLed's Avatar
CharlieLed
I guess that it is an FMX, in my limited knowledge of all things Ford I assumed that since it wasn't a C6 and it had the small square pan, that it was a C4. I did a quick search on FMX trannies and it seems that some folks think that they're super and some that think they aren't. If it is as beefy as some people say and I can keep it running then it sounds like it will work for me.
Old Oct 28, 2007 | 09:59 PM
havi's Avatar
havi
IMO, I'd use it. If anything else, it'll get ya on the road, til you find an AOD, or C4.
Old Oct 28, 2007 | 11:46 PM
imlowr2's Avatar
imlowr2
The 351W usually came with the FMX transmissions as did the 351M or 400W which was in Rancheros. The C4 will also bolt up to the 351W, but not the 351Cleveland. The early C4's were garbage (64-66), they also had the 1-3-2 shift pattern, which meant if you were in 1st, your next click up on the shifter would be 3rd/ Drive. For what its worth, the C4 and FMX are only as good as the rebuilder. The C6 is Fords strongest transmissions. I don't recall the C4 coming in aluminum? The casing is die cast.
Old Oct 29, 2007 | 12:51 AM
Randy Jack's Avatar
Randy Jack
A square pan and steel case is definitely an FMX. I am running that tranny behind a messaged 351C and love it. My tranny guy rebuilt it and added a shift kit. He said it was bullet proof to 450 hp.
Enjoy!
Old Oct 29, 2007 | 06:20 AM
GreatNorthWoods's Avatar
GreatNorthWoods
It may be a little heavier but an FMX is just as good a transmisison as the C4.
Old Oct 29, 2007 | 07:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There were two FMX's in 1969 with a C9ZP code. Look on the left side of the case for the Ford Transmission ID tag. If the code on that tag is: PHB-E, it was used on the 351W 2V's. If PHB-H...it was used on the 351W 4V's.
The C9ZP code means that the trans was originally in a Mustang.
