psi = what CR on FE's
Does any of you knowledgeable users have a table which will give an estimated psi for any set CR?
Like 10.0:1 = 200psi ....
Knowing that there are a lot of variables that impact these number.
And with AL heads how high can the compression be before you start having detonation problem with Pump Gas, 89-91 octane.
Actually figuring all the areas (CCs) of the parts and doing the math will get you very close. Cam overlap can play a role, but you have to get pretty radical to change it much. Another note, when doing a test with a gauge screwed into the plug holes, all the plugs need to be out, and the throtle plates in the carb wide open....aMP
