Offroad & 4x4
4x4 hubs
Old Oct 28, 2007 | 12:40 PM
menzfamfour's Avatar
menzfamfour
4x4 hubs
1985 4x4 when i lock the hubs i here somekind of rubbing what could that be
Old Oct 28, 2007 | 01:04 PM
STGFordCrazy04's Avatar
STGFordCrazy04
OK Im a little confused by what you mean. I guess you are saying that you hear a noise when you lock and unlock your hubs. Is this a new problem that just started or has it always been there an you just now started to pay attention to it? With this very minimum info Ill give my opinion. When you twist the **** the internal spring applies pressure to the locking ring thus locking your axles in 4wd. The pressure on the inner face of the hub makes a little noise and is just the nature of the beast.
Old Oct 28, 2007 | 01:12 PM
menzfamfour
its not that click its when i lock the hubs in 4x4 i here some kind of rubbing in the drive side front tire it just started
Old Oct 28, 2007 | 01:14 PM
menzfamfour
while the tires are moving i here the rub
Old Oct 28, 2007 | 03:53 PM
STGFordCrazy04
wheel bearings. change them out.
Old Oct 29, 2007 | 02:39 PM
flareside_thunder's Avatar
flareside_thunder
Don't get too hasty....could be the bearings could be crap behind the rotor.....or it could even be the driver side axle shaft.......
JR
Old Oct 29, 2007 | 04:43 PM
STGFordCrazy04
With this small amount of info its my best guess. If the wheel bearings havent been changed since 1985 Id do that anyway. Maybe give us a little more info or take it to a front end shop who could help fix your problem.
Old Oct 31, 2007 | 08:37 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
sounds like the outside tire shoulders are rubbing on the muffler get muffler service
Old Oct 31, 2007 | 06:01 PM
STGFordCrazy04
Could also be a squirrel trapped inside the coil spring and hes rubbing his nuts against the rungs.
By nuts I mean food
Old Oct 31, 2007 | 11:31 PM
rebocardo's Avatar
rebocardo
If it only does it when the hubs are locked in, there is a good chance the UJ on that shaft is bad. If it is more like a clicking sound, the hub could be bad or misassembled.
Old Nov 19, 2007 | 10:25 PM
Scotty_O's Avatar
Scotty_O
i got a similar problem but my truck makes a loud humming noise when the hubs are in any ideas?
Old Nov 19, 2007 | 10:36 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
i get a very loud humming too....but thats only if the boggers are rolling....hahahaha
Old Nov 19, 2007 | 10:37 PM
Scotty_O's Avatar
Scotty_O
i dont got big tires
Old Nov 20, 2007 | 09:13 AM
quadzjr's Avatar
quadzjr
i was just messin with ya man.....
rockcrawler_101
Jun 2, 2013 02:27 AM
koski19
Jan 8, 2013 01:34 PM
syannuzzi
Sep 7, 2007 01:20 PM
millermad
Nov 30, 2006 01:44 AM
plb150
Offroad & 4x4
Apr 9, 2004 09:48 AM
