Extra cables through firewall???
Old Oct 27, 2007 | 09:46 PM
javi2001's Avatar
javi2001
Hi guys, I'm needing to pass some more electrical wires for accessories from Passenger Cab to Engine compartment BUT...
I don't want just make a hole on the firewall to pass them, some of you can recommend me some kind of connector, water-proof, to do it???
Thanks in advanced for any comment/help
Old Oct 27, 2007 | 10:26 PM
mhg's Avatar
mhg
I just make a small hole with a punch at the
boot at the steering column
once the wire is where I want it and tied down
I seal the penetration with butyl rubber compound
Old Oct 28, 2007 | 08:52 AM
lostin90s's Avatar
lostin90s
You can get rubbers plug/groment for after you drill hole . install plug there in hole you made and there is thing spot in middle that you can make hole in and run wires through. Or like said run in alone one of other penetrations. Later
Old Oct 28, 2007 | 10:10 AM
i1dery's Avatar
i1dery
is'nt there already plugged holes that are just waiting to be used?
I mean my 89 f250 has a couple on the fire wall that i used to route the coax for my cb.
Old Oct 28, 2007 | 11:09 AM
rikard's Avatar
rikard
I cheated and ran some lines from the engine compartment through the fenders and into the cab.
regards
rikard
Old Oct 28, 2007 | 09:02 PM
javi2001's Avatar
javi2001
Thanks guys for all answers. I'm looking for some kind of connector, because in my previous truck, I have installed a lot of wires through a rubber boot without connector, but after a mayor damage to my passenger cab, I hab to replace it, so I have to cutt all wires also.
I really prefer some kind of water pack connector or somenthing similar, I need to pass some low current wires but some AWG #10 also...
Any more ideas?
Old Oct 29, 2007 | 05:53 AM
92F150Flare's Avatar
92F150Flare
Marine parts stores will have waterproof pass throughs. Shops that work on outboards and boats will have that type too. Be prepared to pay......the word "marine" usually triples the price........sorta like the words "Ford dealer"
Good Luck
Bob
Old Oct 29, 2007 | 11:02 AM
tecgod13's Avatar
tecgod13
Any more ideas?
I was thinking the same thing for some wiring I'm going to run on my truck. All I need are low current wires so I was going to use a 4-flat trailer connector. Cheap and easy solution, get a trailer wiring kit and use the short end for the inside cab wiring, the long end for engine compartment to wearever. Pass the wires from the engine compartment through whatever hole/grommet you choose, so the connection is in the engine compartment.
I don't know what you could do for the AWG #10 wires. I don't know if they have fully insulated butt or spade connectors for wires that big, but you could use them and fill with dielectric grease to make it 'waterproof'.
Old Oct 29, 2007 | 11:35 AM
RexB's Avatar
RexB
Here's multipin bulkhead connectors, and their higher-amp page has connectors should fit that AWG10
http://www.route66supply.com/store/page19.html
and firewall http://www.alvatek.com/cms/mil-c-265...FRpIYAodsiNXMA and a catalog of many types, it may have just what you're looking for... http://www.newark.com/jsp/search/browse.jsp?N=1000060
Old Oct 29, 2007 | 07:31 PM
javi2001's Avatar
javi2001
Ok guys, thanks for the info and Links. I need couple of AWG#10 for the Subwoofer Audio amplifier.
Old Oct 29, 2007 | 07:40 PM
javi2001's Avatar
javi2001
Hey RexB the Route 66 connector are axactly what I'm looking for... Thanks
Old Oct 31, 2007 | 09:35 AM
RexB's Avatar
RexB
Glad they can work, post again about how the firewall-holing, weatherproofing and wiring goes
Old Dec 30, 2007 | 08:36 PM
javi2001's Avatar
javi2001
Angry
Bad news... I did order some connectors to Route66 supply one month back and until now I did not receive any answer, no products, no phone number to call, several no answered emails, etc etc...
Anyone have some more ideas about connector providers...?
Old Dec 30, 2007 | 08:52 PM
96onefifty's Avatar
96onefifty
Your truck is an auto, Right? If so, you can unbolt the plate they use to cover the Clutch master cylinder hole, thats how I ran my amp power wire and such. and its alot easy to drill a hole in something thats off the truck.
Old Dec 30, 2007 | 09:10 PM
95F350XL's Avatar
95F350XL
I had to run some wires to test some subs and amps out, so I ran the wires under the truck and then into a drain plug under the carpet, Just had it like that for a day to so. But yea just use some male and female spade conncetors where the wire passes through the firewall. They sell waterproof ones also. Then silicole the hole up once your done.
