I have taken all of the emission stuff off of it,I have no vacumn leaks,and have replaced the carb,stock 2 barrel.No catalyic converter.Timing is OK,yet stumbles under load. Vacumn advance is working. My first guess is the distributor. It is the original with 183,000 miles. Any thoughts?
Yes to the fuel filter. It could have enough flow to run the engine at idle but with a partial blockage it would not have enough flow to run under a load. I had this scenario a few months ago.
What If the dist. had loose bushings and is no longer running in a round circle but was loose in its hole 183,oo mile thats a lot of rotation for a dizzy
