Sponsored by: Real Truck
Exhaust/muffler
Old Oct 27, 2007 | 05:33 PM
bmvtr's Avatar
bmvtr
Unhappy Exhaust/muffler
I have a 5.4 F-250 with single in and out 40 series flowmaster. But Iv'e noticed on my brothers 4.6 F150 same muffler his is alot louder then mine his is ran the same as mine. Also my neighbors 5.4 F150 is louder then mine and he had dual 40 series installed. I understand that the duals would be louder but is the big difference between the 4.6 and the 5.4 setup the catalytic? And would buying the Y pipe off of ebay for the 5.4 make a difference in sound? and loudness?
Any thoughts or comments would be appreciated.
Old Oct 27, 2007 | 05:50 PM
mstiles19's Avatar
mstiles19
saw the muffler off! then it will be loud!
Old Oct 27, 2007 | 05:56 PM
sglaine's Avatar
sglaine
Posting Legend
I drove an 2004 Super Crew last Saturday with a Flow Master and I thought it was noisy as a screaming Hag....LOLThat truck also has a 4.6
Old Oct 27, 2007 | 06:02 PM
bmvtr's Avatar
bmvtr
Ive removed the muffler before it sounds nasty when you get on it.
Old Oct 27, 2007 | 06:05 PM
dkf's Avatar
dkf
The Super Duty 5.4l and 6.8l gassers from 99'-04' have a very restrictive y-pipe from the factory. There is a small section on the Y-pipe that necks down to a very small 1.5" pipe to help eliminate the exhaust flutter from the 6.8l. The 5.4l and 6.8l SD use the same exhaust.
I recommend getting a Stans or Ebay y-pipe and have it installed on your SD. The Y-pipe not only increases low end power considerably under 3k rpm it also makes the exhaust much louder as well. After changing the Y-pipe I would not be surprised if its a little too loud for you. I was very surprised about how much the exhaust note changed after I installed mine.
The F-150s have a different more free flowing y-pipe design from factory which will make them sound louder.
Old Oct 27, 2007 | 06:36 PM
bmvtr's Avatar
bmvtr
What is that flutter that the guy on ebay and you talk about dkf ?
Old Oct 27, 2007 | 10:08 PM
sglaine's Avatar
sglaine
Posting Legend
Good point and cheaper also..
Old Oct 28, 2007 | 01:54 PM
dkf's Avatar
dkf
Its sort of an annoying little sound that is somewhat hard for me to describe. Almost sounds like a very small exhaust leak. The 6.8l produces the flutter do to the firing order. The 5.4l doesn't suffer from flutter as far as I know. Flutter usually occurs around 2k rpm and only lasts a couple hundred rpm or so depending on load. Its somewhat subtle and is heard best when all the windows are up. My dad has the Ebay Y-pipe on his 03' 6.8l and flutter is very very minimal and hard to hear. I made a custom Y-pipe for my 04' 6.8l as well but I don't have it on anymore since I got a set of Thorley headers on. In my truck and my dads truck low end power was noticeably increased.
Old Oct 28, 2007 | 03:35 PM
bmvtr's Avatar
bmvtr
Alright thanks guess ill be buying the pipe this week.
Old Oct 28, 2007 | 05:33 PM
chuck06250's Avatar
chuck06250
Here's the Y pipe on Ebay-
http://cgi.ebay.com/ebaymotors/00-04...spagenameZWDVW
Old Oct 28, 2007 | 07:32 PM
mstiles19's Avatar
mstiles19
or instead of spending 80 bucks on a y pipe you can get a cut out for 32 with that you can make it loud when u want it and quiet whenu need it quiet
Old Oct 28, 2007 | 08:05 PM
hugo0612's Avatar
hugo0612
Smile
hey buddy if you are installing the Y pipe from ebay, please let me know how it goes. I am thinking to install one on my truck too. thanks, Hugo hugo0612@hotmail.com
