Fuel gauge issues
Old Oct 26, 2007 | 11:22 AM
sum_weirdo's Avatar
sum_weirdo
Fuel gauge issues
Ever since I bought my truck the fuel gauge will only work when the truck is warmed up. Usually that's meant I'll have to drive it for 10 minutes before the gauge will wake up and rise above empty. And now that it's getting colder outside it hasn't been coming on at all half the time. Any ideas about what to do with this?
Old Oct 26, 2007 | 01:38 PM
Mil1ion's Avatar
Mil1ion
A mere coincidence.
You have a grounding or power signal wire problem.
You need to inspect/clean/secure all connections to get everything (the way it should be) before going inside the tank or behind the dash.
https://www.ford-trucks.com/forums/1...uel-gauge.html
https://www.ford-trucks.com/forums/1...-1-2-mark.html
https://www.ford-trucks.com/forums/1...f-the-peg.html
Old Oct 26, 2007 | 03:20 PM
m78's Avatar
m78
sounds like your temp sending unit is hooked up to your gas gauge
Old Oct 26, 2007 | 03:36 PM
sum_weirdo's Avatar
sum_weirdo
Nah I know what the temp is by lookin at the radio.
Old Oct 26, 2007 | 04:18 PM
Mil1ion's Avatar
Mil1ion
If you look at the temp gauge do you see the radio station numbers ? *grin*
Old Oct 26, 2007 | 04:29 PM
sum_weirdo's Avatar
sum_weirdo
Post
May as well The temp gauge is kinda suspect too actually. In this weather it hangs just on the edge of normal. And I just realized yesterday the amp gauge points straight up whether the truck is on or not. Not to mention the dome light doesn't work even after a bulb change. I really should check the fuse panel I think. And I'll be checking the plug on the fuel sending unit too like someone mentioned in one of those posts you linked to.
Old Oct 26, 2007 | 04:51 PM
Mil1ion's Avatar
Mil1ion
The only things that run on the ICVR are the
Oil/Fuel/Temp gauges
check the connector on any one of these for a constant pulsing of 5 volts
"A Regular pulse"
Pulse.....pulse.....pulse.....pulse.
If it is slow or fast then there si a provblem with the ICVR output or its ground.
