stacked chips
Old Oct 25, 2007 | 11:09 PM
Tryan7's Avatar
Tryan7
stacked chips
can you stack a dp-tuner with an edge ez box? or any other chip?
Old Oct 25, 2007 | 11:12 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Don't know. I suppose the question would be why? The DP doesn't leave a lot on the table and stacking may be asking for trouble.
Old Oct 26, 2007 | 01:54 AM
kupaa's Avatar
kupaa
the dp is all you realy need.
Old Oct 26, 2007 | 08:01 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
The Edge box fools the PCM into thinking the HPOP pressure is lower than it is. The PCM then makes a decision on what to do with IPR duty cycle to compensate. This is a "corrupt" signal. Garbage in = garbage out.
The DP Tuner chip (or other Physical "chips") that piggyback on the PCM use the data from sensors and actually bypass the PCM's own internal fuel and timing maps to make the decisions on what to do with the data. Using ACTUAL sensor readings allows the CHIP to make "educated" changes to IPR and timing.
Stacking a "fueling box" with a chip usually causes severe overfueling, very high EGT, and SES lights due to "out of range" ICP readings/low HPOP.
You didn't ask about "tuners" (reflashing devices), but the effects of stacking a "fueling box" with a "tuner" usually results in the same fashion as stacking the chip/box.
You can't stack a "tuner" with a "chip". The chip will ALWAYS bypass the tuner's programming since the chip bypasses the EEPROM in the PCM.
In addition, unless there is programming present to compensate for transmission parameters (line pressure, timing, duty %, etc.), using a fueling box only will cause a slushy (and eventually burned up) auto transmission.
DP Tuner tunes are all you will need.
