Smoking F150 is embarrasing
I have a peculiar problem that is very embarrassing. If I start my 2006 F150 5.4 L and shut it off within a minute or 2, the next time that I start it, it will blow out a huge cloud of blue smoke. It doesn't do this after a normal drive when the engine has been warmed up, it only does this following a short start, then shut off, then re-start (as described above). It has done this since brand new, I thought that I would wait until it was broke in to see if it went away. The truck is now 1 year old and has 7000 miles on it with plenty of TLC. This is the first new truck that I have ever owned and am sad to say that I wish that I didn't own it. Does anyone have any ideas?
Discouraged.
Discouraged.
definitely check the oil, and maybe even spark plugs... PCV may also be a culprit... my mustang used to let off blue smoke on decel and a bit on start up if i shut if off right after i come to a stop. i put a catch can on the pcv and that fixed it... I know these trucks are quite a bit different, but i don't see the pcv working much different...
actually that is a common thing for ohc engines -- i am not sure why but 4.6 and also 3.9 engines do this too,always after a cold start with a short run and then restart. i do not think it hurts anything and you wont notice any undue oil usage. to avoid it just run the engine longer on a cold start before shutoff and you wont see the smoke.
jim
jim
smoking
Originally Posted by 04 FX4 Lineman
Is it using any oil?? What kind and weight of oil are u using, should be using 5W20 syn. blend oil, my 04 has never done that and does not use any oil in 4K which is where I change due to a lot of short driving.
smoking
smoking
jim
jim
smoking
Originally Posted by fordtruckman
What are you doing that you would start your truck and shut it off after 2 mins and then restart the truck?
I do not mean to be throwing a wrench into the engine, but I have been told time and time again, that if you are seeing blue smoke in quantity on start up when it is warm, it means one of two things. A sticking intake valve, or worse case, the timing is off. Either way unless you are a qualified mechanic, I would take it to the dealer or a good reptuable mechanic.
These rigs cost way too much to second guess.
Good luck, and if you can, post the out come of this.
Oh, I am a wood worker, just to knock down the people who might think I am a mechanic.
smoke
