Smoking F150 is embarrasing
Old 10-25-2007, 04:43 PM
jlsdcen2's Avatar
jlsdcen2
jlsdcen2 is offline
I have a peculiar problem that is very embarrassing. If I start my 2006 F150 5.4 L and shut it off within a minute or 2, the next time that I start it, it will blow out a huge cloud of blue smoke. It doesn't do this after a normal drive when the engine has been warmed up, it only does this following a short start, then shut off, then re-start (as described above). It has done this since brand new, I thought that I would wait until it was broke in to see if it went away. The truck is now 1 year old and has 7000 miles on it with plenty of TLC. This is the first new truck that I have ever owned and am sad to say that I wish that I didn't own it. Does anyone have any ideas?
Discouraged.
Old 10-25-2007, 04:57 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
04 FX4 Lineman is offline
Is it using any oil?? What kind and weight of oil are u using, should be using 5W20 syn. blend oil, my 04 has never done that and does not use any oil in 4K which is where I change due to a lot of short driving.
Old 10-25-2007, 04:58 PM
jstnromero's Avatar
jstnromero
jstnromero is offline
sounds like oil is being burnt....are you burning or going through a lot of oil?
Old 10-25-2007, 05:00 PM
Fosters's Avatar
Fosters
Fosters is offline
definitely check the oil, and maybe even spark plugs... PCV may also be a culprit... my mustang used to let off blue smoke on decel and a bit on start up if i shut if off right after i come to a stop. i put a catch can on the pcv and that fixed it... I know these trucks are quite a bit different, but i don't see the pcv working much different...
Old 10-25-2007, 05:21 PM
dartguy699's Avatar
dartguy699
dartguy699 is offline
actually that is a common thing for ohc engines -- i am not sure why but 4.6 and also 3.9 engines do this too,always after a cold start with a short run and then restart. i do not think it hurts anything and you wont notice any undue oil usage. to avoid it just run the engine longer on a cold start before shutoff and you wont see the smoke.
jim
Old 10-25-2007, 06:33 PM
jlsdcen2's Avatar
jlsdcen2
jlsdcen2 is offline
smoking
It doesn't use oil excessively. 1/2 quart in 3000 miles. Yes I use the recommended Motocraft 5W-20 and Motocraft filter, everything by the book.
Old 10-25-2007, 06:36 PM
jlsdcen2's Avatar
jlsdcen2
jlsdcen2 is offline
smoking
It doesn't use oil excessively, maybe 1/2 quart in 3000 miles. This truck only has 7000 miles, still smells new inside.
Old 10-25-2007, 06:45 PM
jlsdcen2's Avatar
jlsdcen2
jlsdcen2 is offline
smoking
What is a "catch can" that you spoke of puttting on the PCV valve?
Old 10-25-2007, 06:48 PM
jlsdcen2's Avatar
jlsdcen2
jlsdcen2 is offline
smoking
jim
Hmmm, I never see this happening from anyone elses truck. I hope that no Chevy, Dodge, or Nissan owners see this happening, it might hurt Fords reputation!
Old 10-25-2007, 06:55 PM
fordtruckman's Avatar
fordtruckman
fordtruckman is offline
What are you doing that you would start your truck and shut it off after 2 mins and then restart the truck?
Old 10-25-2007, 07:07 PM
jlsdcen2's Avatar
jlsdcen2
jlsdcen2 is offline
smoking
Ocassionally I move it out of my garage so I can work on other things. You don't have to restart it right away, just count on it to smoke the next time you start it. I never realized this, until I bought this truck, that an individual might move their vehicle short distances, but sometimes the need to do so is there. I try to avoid doing such, but irregardless, I don't think a new vehicle should do this, should it?
Old 10-25-2007, 07:22 PM
KevinAH's Avatar
KevinAH
KevinAH is offline
seems like a half quart every 3000 is about a half quart too much. I'm no mechanic but I have always been advised to watch out for oil consumption.
Old 10-25-2007, 07:56 PM
smokestone52's Avatar
smokestone52
smokestone52 is offline
I do not mean to be throwing a wrench into the engine, but I have been told time and time again, that if you are seeing blue smoke in quantity on start up when it is warm, it means one of two things. A sticking intake valve, or worse case, the timing is off. Either way unless you are a qualified mechanic, I would take it to the dealer or a good reptuable mechanic.
These rigs cost way too much to second guess.
Good luck, and if you can, post the out come of this.
Oh, I am a wood worker, just to knock down the people who might think I am a mechanic.
Old 10-25-2007, 08:05 PM
jlsdcen2's Avatar
jlsdcen2
jlsdcen2 is offline
smoke
You are correct to say that these rigs cost too much, $34600 and it smokes 10x more than my old tired trade in!
Old 10-25-2007, 08:48 PM
KevinAH's Avatar
KevinAH
KevinAH is offline
Na, I usually only see older vehicles smoking. You should have it looked at otherwise it's going to continue to bother you until you really know what the problem is or isn't.
