Sponsored by: Real Truck
Speedo Acting Goofy
Old Oct 25, 2007 | 08:43 AM
jomac11's Avatar
jomac11
Speedo Acting Goofy
On my way to work today my speedo started acting goofy. It was about 20mph off (I checked this by accelerating until it wouldnt anymore or 95mph) and determined that it was around 20mph off. Anyways, when I parked it, the speedo dropped to about 22mph, and it stayed there when I shut it off. I guess a trip to the dealer is probably in order, but what do you guys think could be causing this?
Old Oct 25, 2007 | 09:20 AM
npccpartsman's Avatar
npccpartsman
VSS or speedo panel--depending on mileage take it to the dealer.
Old Oct 25, 2007 | 09:32 AM
jomac11's Avatar
jomac11
Just turned 8k on the way to work yesterday. What are the odds that they will try to blame it on my remote start/alarm?
Old Oct 25, 2007 | 09:48 AM
nubeee1's Avatar
nubeee1
Mine did it for about 2 days. Same thing as yours. On the way to work, was doing about 35mph, it jumped up to 65. Its stayed at 30 mph over what the actual mph was. (It stayed at 30 when parked) Then it would drop by 5 mph each time I turned it off. It eventually went back to 0. That happened 6 months ago, and hasn't happened since.
Old Oct 25, 2007 | 09:56 AM
jomac11's Avatar
jomac11
I might go try to cycle the key on my lunch break.
Old Oct 26, 2007 | 09:18 AM
jomac11's Avatar
jomac11
When I went home yesterday it was down to 15, and then went to the store last night it was at 10, this morning it was back to almost normal. Drove to work, and now its back up to 25. Guess I'll have to get it to the dealer on monday...
Old Oct 26, 2007 | 12:26 PM
LvTitan's Avatar
LvTitan
weird. never seen that before
Old Oct 26, 2007 | 10:47 PM
Got Rattle's Avatar
Got Rattle
Just disconnect the negetive cables from BOTH batteries, at the same time , for a few minutes. It will reset to zero.
Old Oct 27, 2007 | 02:38 PM
Grey 250s's Avatar
Grey 250s
Exact same thing happened to me at about 10k. Strange feeling to be idling through a parking lot with the speedo reading 45 mph. Dealer said there is a TSB out on the speedo hanging up. Ordered in a new instrument cluster (out of Seattle) and swapped it out on warrenty. It works just fine now at 26k.
Easy swap. Took 'em about 45 minutes.
'06 F250 SD 6.0
