Sponsored by: Real Truck
18" Tire Help
Old Oct 24, 2007 | 11:40 PM
WEFITE4U's Avatar
WEFITE4U
18" Tire Help
I searched for the last two days and cant find an answer to my question. I am hoping someone can help me out.
I have an 04 F250 Kingranch with the stock 18x8 Wheels. I am looking at getting 33x13.5 ProComp Xterrains. The ProComp site says that they can be run on an 8" rim so that shouldn't be a problem. My question is, will they fit the truck without rubbing?
I am trying to get the biggest tire possible on the stock rims until i do the lift and 38's. Coming back from Iraq and transferring duty stations at the same tiem has put my lift plans on hold until spring. Thanks for any input.
Old Oct 25, 2007 | 07:39 AM
PowerStrokeHD's Avatar
PowerStrokeHD
Using stock wheels you will have will have rubbing problems on the front leafs with a 13.50" wide tire.
Also the size tire you are looking at actually require a 9" wide wheel.
Old Oct 25, 2007 | 02:21 PM
ljstoy's Avatar
ljstoy
That tire size doesn't "require" a nine inch wheel but yes, it will rub the leaf springs. You probably need to stick with a 12.50 and they still may rub a tad bit when you turn as sharp as you can. Depends on the offset of the wheel. 35 x12.50 or 315/75 or easier and cheaper to buy anyway.
Old Oct 25, 2007 | 02:31 PM
o'brien's Avatar
o'brien
Just adjust the turn stops on the front axles to stop the tires right before contacting the springs. So easy
Old Oct 25, 2007 | 11:52 PM
WEFITE4U's Avatar
WEFITE4U
I was under the impression that 35s and 315s would not fit without atleast a leveling kit. Am i mistaken?
Old Oct 26, 2007 | 07:22 AM
PowerStrokeHD
I am running 35's on my stock '04. I could not guarantee that it would fit on your truck, nor would I recommend it for everyone. It is a very tight fit.
Old Oct 26, 2007 | 08:33 AM
ljstoy's Avatar
ljstoy
I've had 35 or 315's on my 01',03',06',08' SDs without any problems. I average about 50k miles a year which equals to about 2 sets of tires per year but other than that, no problems with no lift or special wheels other than factory.
