5.4l swap
Old Oct 24, 2007 | 06:42 PM
danger-ranger's Avatar
danger-ranger
5.4l swap
I was wonder what all could be taken off the 5.4l to make a swap into a 1981 f-150, and still keep it runable. thanks
Old Oct 25, 2007 | 01:30 AM
LxMan1's Avatar
LxMan1
Not much, you will need all of the electronics and comparable fuel system as well as most of the emissions componants to keep it from throwing a CEL and going into limp mode. A custom tune may allow you to eliminate alot of this stuff. You will also need the mating transmission.
Old Oct 25, 2007 | 10:49 PM
danger-ranger
i would like to take off emission stuff cause i do not have emissions
Old Oct 28, 2007 | 03:47 PM
LxMan1's Avatar
LxMan1
you can eliminate the rear 02 sensors, but will need the front ones for it to run. I would leave the EGR valve, it will reduce detonation at part throttle. You will need custom programming to eliminate the evap system.
