Think all is well
Old Oct 24, 2007 | 12:46 PM
WonderDonkey's Avatar
WonderDonkey
Think all is well
So i have had fuel in my degas bottle for a while, i also had some starting issues. My truck would start easy so i eliminated glow plugs and relay, but it would run rough and smoke for about the first min. Well i replaced all my fuel cups( not that bad) and now i dont have fuel leaking into my degas bottle and my rough running white smoking starts have gone away.
Best i can see is when truck was shut down and lost injector pressure, the cooling system still being warm with pressure pushed coolent into my fuel cup causing rough idle and smokey start. Thats the best i can come up with.
Also replaced UVC cause of p1316 code which turns out to be #4 and #5 short code, but that didnt help. guess i better pull the wiring completley out.
Last is i noticed a crack in two of my IC boots, anyone know where to get em?
Old Oct 24, 2007 | 01:03 PM
bdrummonds's Avatar
bdrummonds
Check here for new upgraded versions http://www.dieselsite.com/index.asp?...ROD&ProdID=133 At the bottom of that page is a clicky for the 2 Intercooler boots.
Now if you don't want new, I have some stockers in my workshop, you are welcome to them, but I will have to check to see exactly which ones are good.
Old Oct 24, 2007 | 01:06 PM
Zephyr's Avatar
Zephyr
I got my boots here http://www.puredieselpower.com/catal...-30_32_44.html
You can buy an entire set or just the ones you need, I would also recomend upgradeing the clamps.
Old Oct 24, 2007 | 03:41 PM
bdrummonds's Avatar
bdrummonds
Got your PM sent you this one back
Tell you what just PM me your name and address, and I will put the whole box in the mail tomorrow. I will take the bad one out, and the ones I will send will be good ( Ill go out to the shop this evening and see exactly what is in the box, and send you another message)
No cost, just pass on some parts when someone else needs them
jhl3
Dec 5, 2014 06:14 AM
bkuuz1
34
Jun 26, 2014 10:30 PM
Number21
Jun 16, 2014 10:04 PM
hwknsdrag
Jan 21, 2013 09:27 AM
PowerstrokeJunkie
87
Aug 5, 2008 12:21 AM
