Sponsored by: Auxito
Outside temp display WRONG (auto cli. cntrl)
Old Oct 24, 2007 | 07:11 AM
redsodie's Avatar
redsodie
02 - f150
[font='Verdana','sans-serif']automatic climate control (Outside temperature) - why all of the sudden would the reading on my outside temperature start reading too high? it’s like 45 degree out here in IN. and my outside temp says its 84....steady climb as I drive? any thoughts?[/font]
Last edited by redsodie; Oct 24, 2007 at 07:14 AM. Reason: early morning spelling.....sssshhhheeeeeshhhh
Old Oct 24, 2007 | 07:29 AM
LxMan1's Avatar
LxMan1
Sounds like the sensor is failing, but hard to say for sure. There isn't a large bug or something blocking airflow to the sensor is there?
Old Oct 24, 2007 | 07:32 AM
redsodie's Avatar
redsodie
can those sensors be replaced easily?
It’s possible.... on the debris...I will have to look
Except…where exactly is the &^#* thing located…lol
Old Oct 24, 2007 | 11:13 AM
KingRanchMan02's Avatar
KingRanchMan02
It is under the hood, on the right side near the front of the vehicle. Two wire connector that is mostly round but has one corner. Wires are Pink/Black and Light Blue/Orange.
If you do an advanced search for threads that I have posted and using the keyword of "EATC" in the 1997-2003 forum, you will find the procedure to put the EATC into diagnostic mode. When the search results come up, look for a thread posted by oscar_007, titled "air vents". Good luck!
Old Nov 1, 2007 | 01:52 PM
redsodie's Avatar
redsodie
OK.....I found the sensor....replaced it with a new one....
now my outside temp displays 10 degees ..it not that cold out.....YET!
does the pcm need to be reset? or what else could it be?
im going to check sensor resistance with an ohm meter at room temp tonight?
Old Nov 1, 2007 | 03:51 PM
KingRanchMan02
The electronic automatic temperature control (EATC) head unit has built in diagnostics to troubleshoot system problems. Did you check the EATC head unit for trouble codes as I suggested? Good luck!
Old Nov 1, 2007 | 03:59 PM
redsodie's Avatar
redsodie
yep...sure did!
no trouble codes indicated
Old Nov 1, 2007 | 04:04 PM
KingRanchMan02
You could reset the EATC to see if that helps.
Old Nov 2, 2007 | 07:04 AM
redsodie's Avatar
redsodie
ok....well.....yesterday when I replaced the sensor it was at lunch time.....(easy install) anyway, right after I put the new one in, it wasnt working...false reading. Then I went outside after work to drive home and its been reading correctly ever since.....hmmm, dont know. But, non the less, I'm happy its working!
thanks for all the help....this board is great!
Old Nov 2, 2007 | 10:06 AM
KingRanchMan02
Glad that you got it fixed and that I could help!
Old Nov 4, 2007 | 06:38 PM
LxMan1's Avatar
LxMan1
They don't react real fast, so it probably took a bit to read correctly.
Old Feb 12, 2008 | 01:23 AM
Rod L's Avatar
Rod L
I have a 2000 f150 an my outside temp readout is 140f all the time does this sound like a sensor problam
