4x4 lounch
Well I got rid of my auto hubs a long time ago, right after I figured out that the vacumn was part of the reason the unit bearings go out. after replacing my bearings then about 10,000 miles later having to take one side apart to replace the ball joint I found a LOT of grease sucked out of that new bearing. disconnected and plugged the vac line and 30k miles later guess what all the grease is still in teh "sealed" bearing and not spread throughout the hub itself and no more issues wiht bearings going out.
So I installed a set of Warn lockouts and viola no more problems with my front end.
Originally Posted by kupaa
was just wondering,but the manual says to keep it under 45mph.
Also it won't shift out of 4wd until you're under 50 mph. At least on my truck it will shift out at 49 mph. Some others might vary a bit.
