ford f150 trans trouble i have a couple of ?'s
is there a direct swap 4 a 91 ford f150 with a 5.0 e4od trans or one that is close without doing alot of coustomization work please write me back mine is vibrateing when i go up hills and push down on the gas and some times whenever i am on a str8t away if you can help me it would be apritiated thanks chris
The AODE made in livonia will bolt up to the back of the engine, but you'll have to wing it on the driveshaft length, trans mount, and electrical hookup. I would look in the salvage yard for a truck with one and take the trans, driveshaft, transmount, wiring parts, and any other pretinant parts that you don't have. You probly need the PCM also because it will be programmed for the AODE trans. Best guess.
Welcome to FTE
I'm guessing you have already checked fluid and even changed it along with the filter?
Might well be worth doing unless you have someone very knowledgeable telling you your trans is toast. Even then I would check into a rebuild rather than replacement.
Best and easiest swap will be a direct replacement. Same year, model "etc".
Good Luck
Bob
Good Luck
Bob
