Disassembling Dash
Old Oct 23, 2007 | 07:29 PM
BigBad352's Avatar
BigBad352
Disassembling Dash
Ok I got a '93 F-150 and i want to put a new cd player in but Im not sure how to get the old one out...how do I take the dash apart to accomplish this?
Thanks-
Old Oct 23, 2007 | 07:39 PM
tomtoc's Avatar
tomtoc
shouldn't have to take apart the dash at all. go to auto parts place and get the right tool - it's just a couple bucks. its a little u-shaped metal place that you shove in the factory holes and pull it out
Old Oct 23, 2007 | 07:41 PM
subford's Avatar
subford
You do not take the dash apart.
Go to Wal-Mart and buy a set of ford radio removal tools, put them in the four holes and pull it out.
Old Oct 23, 2007 | 07:48 PM
BigBad352's Avatar
BigBad352
Sweet! thanks. One more question..what about the instalation of the new cd player then?
Old Oct 23, 2007 | 08:03 PM
tomtoc's Avatar
tomtoc
should be no problem. while you're are auto store get the wiring harness (also a few bucks). should be pretty to hook up.
Old Oct 23, 2007 | 09:03 PM
BigBad352's Avatar
BigBad352
Is the wiring harness necessary or can I just splice the new one in?
Old Oct 23, 2007 | 09:10 PM
17fordguy's Avatar
17fordguy
u can ju st splice in the new one
Old Oct 23, 2007 | 09:11 PM
BigBad352's Avatar
BigBad352
Is therea trick to doin it with all those wires?
Old Oct 23, 2007 | 09:17 PM
tomtoc's Avatar
tomtoc
yea, like i said above, buy a wiring harness. they're just a few bucks and made to do exactly that. each one is clearly labeled where it needs to go.
Old Oct 23, 2007 | 09:26 PM
BigBad352's Avatar
BigBad352
I just got back from Wal-Mart, I got the tool, but I didnt see a wiring harness. Where else would I get one?
Old Oct 23, 2007 | 09:28 PM
tomtoc's Avatar
tomtoc
got mine from autozone. i'm sure any place like that has them. just a plug that plugs into the stock stereo plug with wires hanging out the other side to attach to your stereo.
Old Oct 23, 2007 | 09:38 PM
BigBad352's Avatar
BigBad352
Ill check there tmw. thanks!
Old Oct 24, 2007 | 01:44 AM
TexasGuy001's Avatar
TexasGuy001
Don't splice the wires onto the oem wiring. Just get the adapter harness for a few bucks and splice it onto the new radio wiring.
Old Oct 24, 2007 | 10:40 AM
quicklook2's Avatar
quicklook2
this does not save money.
buy the wiring harness.
Old Oct 24, 2007 | 11:21 AM
jimbo beam's Avatar
jimbo beam
Do yourself a favor a get a adapter harness, they're only 4 or 5 bucks, any place that sells car audio stuff should have them.
The wires on the adapter and the cd harness will be the same colors, I just striped the wires and twisted them together, and then covered them with electric tape.
The cd player will fit perfectly in the factory radio hole, you may need to force it alittle to get it all the way in there.
