General Automotive Discussion
Small gas container under bed cover
Old Oct 23, 2007 | 06:27 PM
gregghealy's Avatar
gregghealy
Is it safe to travel with gas in a legal container underneath a closed fiberglass bed cover? Is there any ventilation even though the cover seals out rain? Anybody added some kind of venting to a bed cover...?
Snugtop offically says "they dont recommend" doing it.
Old Oct 23, 2007 | 07:37 PM
Mil1ion's Avatar
Mil1ion
IMO, Only a problem if the weather is hot and the gas can isn't secured from fall over.
Old Oct 23, 2007 | 07:50 PM
ken's 80's Avatar
ken's 80
I am assuming you are refering to gasoline, not propane or another type of bottled gas.
In NJ there is a limit to the amount carried before you must put warning signs on the vehicle and that amount is WELL over ten gallons. I believe it's somewhere around 55 gallons.
It would surely be prudent to make sure the container is secure, well sealed and the bed is ventilated.
Old Oct 23, 2007 | 09:52 PM
gregghealy's Avatar
gregghealy
Looking to mount one of these on a platform I can remove for daily driving. Ill use tie downs or some kind of mounts just in case (God forbid) of a rollover.
I need to figure out a way to let some extra air under the cover and this really shouldnt be anything to worry about I would think.
Thanks.
Old Oct 24, 2007 | 11:22 PM
woodbutcher05's Avatar
woodbutcher05
I would worry more than a little bit.IIRC the fumes from 1 qt of gasoline equals the explosive power of 15 sticks of dynamite.Hehehehehe.
Leo
Old Oct 25, 2007 | 11:23 PM
rebocardo's Avatar
rebocardo
Use a metal fire can safety rated for road use (DOT approved) and fire marshall approved. They run about $35 for 5 gallons. They come with a bunch of small things that count such as anti-flashback.
