Sponsored by: Real Truck
keypad code
Old Oct 23, 2007 | 05:23 PM
lazy_r's Avatar
lazy_r
Question keypad code
hey does any one know where to find the factory keycode? the book says its on the computer module, but i cant find it!
Old Oct 23, 2007 | 05:56 PM
Beerstalker's Avatar
Beerstalker
Check out this thread.
https://www.ford-trucks.com/forums/5...locations.html
Old Oct 23, 2007 | 06:45 PM
lazy_r's Avatar
lazy_r
Thanks beerstalker! i found it behind the ashtray
Old Oct 23, 2007 | 06:58 PM
a-rod's Avatar
a-rod
Well Im having this same problem, I read through all the links and I cant see mine, there doesnt seem to be anything behind the radio that I can see.
Can someone tell me how the radio is removed from these trucks??
Old Oct 23, 2007 | 07:04 PM
LionFan's Avatar
LionFan
I found mine right on the firewall about the same height as the ashtray. There was insulation in front of it so the module wasn't visible until I moved the insulation out of the way, and then I needed a mirror and a flashlight to read the code.
Old Oct 23, 2007 | 07:07 PM
LionFan's Avatar
LionFan
If you just want to take a try at cracking the code, let me know and I'll e-mail you the list of door codes.
Old Oct 23, 2007 | 07:23 PM
lazy_r's Avatar
lazy_r
mine was up real high behind the ashtray on a white sticker.. i mean real, neck KRINKING high!
Old Oct 24, 2007 | 08:46 AM
a-rod's Avatar
a-rod
Does it take a special tool to remove the radio?? Its on an 04.
Old Oct 24, 2007 | 09:08 AM
edjunior's Avatar
edjunior
It should be a couple of little "U" shaped tools, available at Wal-Mart by the car stereo installation accessories. They look like this:
http://www.shop.com/Lisle_Radio_Remo...10012-p!.shtml
Old Oct 24, 2007 | 01:07 PM
a-rod's Avatar
a-rod
alright, I thought so, thanks for the help!
