Sponsored by: Real Truck
Melted plugs again
Old Oct 23, 2007 | 10:20 AM
sowder's Avatar
sowder
Melted plugs again
02 F 250 SD 5.4 auto. at 68,000 miles #3 plug shoots out, repaired it with tim-sert, then had miss in engine 5,000 miles later, turns out 6 plugs and some valves was melted, got engine rebuilt with tim-serts installed in all plug holes, injectors were pluged with dirt, replaced all eight, had fuel system and tank cleaned. ran fine but had to use highgrade gas or it would ping.
now 7,300 miles later started missing shot codes P1299, PO174,po301,PO302,PO306,PO308,PO305. took out plugs all melted (bad). Out of 40 Super Dutys in the fleet this is my problem child. whats next? any ideas?
Old Oct 23, 2007 | 10:26 AM
SpringerPop's Avatar
SpringerPop
My initial guess would be that the engine is running way too lean, thus hot.
If you've had injectors clogged before, I'd be looking for improperly-filtered fuel. Maybe an aftermarket two-micron in-line filter is in your future?
Pop
Old Oct 23, 2007 | 10:33 AM
redford's Avatar
redford
FTE Leadership Emeritus
It could also be a malfunctioning O2 sensor causing the lean condition.
Old Oct 23, 2007 | 11:12 AM
sowder's Avatar
sowder
Changed O2 sensors at rebuild, so It did it on old and new. I'm going to check fuel filter next and see if anythings in it, Then see if the cats plugged. Thanks for the input guys.
Old Oct 23, 2007 | 01:02 PM
dkf's Avatar
dkf
With only 68k on the truck the cat should not be plugged.
I agree it sounds like its running lean. I would check for any leaks in the intake or vaccum leaks. The MAF could possibly be bad because that is what monitors how much air is coming in so the proper fuel can be added.
Did you put in a reman engine or just get the heads rebuilt.
Old Oct 23, 2007 | 01:15 PM
hott-rodd's Avatar
hott-rodd
I'd looking into getting a wideband o2 installed before I really hurt the engine again.
Old Oct 23, 2007 | 01:46 PM
sowder's Avatar
sowder
dkf I Checked for vac. leaks already, swapped MAF with another truck, rebuilt the factory engine that was in the truck.
hott-rodd where do I get more info on a wideband o2? took this thing to dealer after all the work was done the first time just to get it checked and they said everything was fine. after changing plugs this time took it to another dealer they say its fine, I know its not that this will happen again. Thanks again guys
Old Oct 23, 2007 | 03:28 PM
swann79's Avatar
swann79
Man that is NUTS! Good luck combing it over...
Scott
Old Oct 23, 2007 | 08:37 PM
chuck06250's Avatar
chuck06250
You might try checking the fuel pressure.
