bad carb
Old Mar 20, 2001 | 12:45 AM
hotrodford_88's Avatar
hotrodford_88
bad carb
Old Dec 22, 2002 | 04:51 PM
Martys82's Avatar
Martys82
bad carb
well i went a adjuted the timing and put everything back the way it should be and now the only conclusion that i have come upwith is that the newly remanufactured carb i bought is crap so now i need to return it, so anyone that gave me input about the install thanx
Old Dec 22, 2002 | 10:23 PM
Vampiro's Avatar
Vampiro
bad carb
is everything hooked up correctly, as in vaccum lines?
Old Dec 23, 2002 | 04:26 PM
Martys82's Avatar
Martys82
bad carb
yea everything is hooked up right and in good shape, had 3 people look at it, but it all looked good and was in the right place, just a bad carb i guess, and the auto parts store gave me a hard time and i had to cal the rebuilder and talk to him so now im taking it off and sending it back
Old Dec 23, 2002 | 10:06 PM
scamardo's Avatar
scamardo
bad carb
I would suggest calling Recarbco.
www.recarbco.com
They advertise that you bolt the thing on and go. I got a 1 barrel Ford 1101 from them, and sure enough, the carbs deliver.
I did have to make a small mixture change, but the carb is great.
Scamardo
Old Dec 26, 2002 | 03:51 PM
Martys82's Avatar
Martys82
bad carb
well i took the carb back, the air/gas mixture screw had no effect when screwed with and the fast idle screw also had no effect..so i called the reman. and he just said send it back and he will send me a new one so now my truck is just sitting around again...
