elec brake
Old Oct 21, 2007 | 02:39 PM
17fordguy's Avatar
17fordguy
elec brake
ok installing an eletric brake system on truck no manual so it has a ground brake light positive bat and brake does it need constant power or should it be hooked thrue ignition power
Old Oct 21, 2007 | 10:42 PM
EPNCSU2006's Avatar
EPNCSU2006
The power needs to be something substantial (12 ga. wire), so I don't know if you'll find a switched source that can handle the current requirement. Straight to the battery with an in-line fuse near the battery will probably be your best bet. The color scheme is goofy on those brake controllers too, make sure you have the right functions going to the right places.
Old Oct 21, 2007 | 11:20 PM
msb71's Avatar
msb71
What year and model truck is it? some have a factory harness under the dash by the ashtray (Later models do), if so all ya need is a plug and play harness.
Mike
Old Oct 21, 2007 | 11:46 PM
17fordguy's Avatar
17fordguy
well i found the plug under the dash about an hour agoand hard wired to it but now i think i still have a proble the blue wite that goes back to the trailerbrakes has a constant 12volt power is this suppose to be this way or is it a faulty controller.
Old Oct 22, 2007 | 04:57 PM
EPNCSU2006's Avatar
EPNCSU2006
Depending on the controller, it's probably supposed to do that. I know the Tekonsha Voyager controllers will send a voltage out to the trailer to determine if there is a trailer attached or not. Once you hook up the trailer, the voltage should fall off of 12V and vary depending on braking demand.
Old Oct 22, 2007 | 05:44 PM
17fordguy's Avatar
17fordguy
oh ok well thats what it is its an older one though i found it in a van at the salvage yard still gotta get the plug though.
