no heater
Old Oct 20, 2007 | 05:33 PM
helifixer's Avatar
helifixer
no heater
it's starting to get cold here (40 F) in the mornings, anyhow I have no heat from the heater, once the engine gets to Normal temp my ducts are blowing mabe 50 F, the temp control **** feels tight as it is rotated to hot. worked great last year.
Old Oct 20, 2007 | 07:15 PM
seabee cm2's Avatar
seabee cm2
Depending on the year of your truck you may want to look at the cable where it conects to the on/off valve. It doesnt take much to brake them. there may even be a retaining clip that holds down the cable in place could be off . Just as an fyi.... It is always a good practice to cycle the heater once a month to keep the crud from building up in the heater core.
Old Oct 20, 2007 | 07:19 PM
Eric_F250's Avatar
Eric_F250
vacuum lines that drive the valves which control the flow leak- check those.
are the hoses that heat your heater core the same temp? if not, you may be blocked.
also, does your temp control **** feel like it did last year? reason i ask is because stuff can fall through the defrost vents all the way down and block the blend door from operating properly.
check the linkage between the control wire and blend door. maybe it slipped off or broke. if that looks good, the easiest way to figure out if your blend door is blocked (if you have big hands) is to pull the heater core out and look in to the blend door space with an inspection mirror and flashlight. if you have small hands, just reach in there. if the door does not completely seat, you will get cold air mixed with your heat. at 40F, the cold will win.
Old Oct 21, 2007 | 12:20 AM
pff250hd's Avatar
pff250hd
Also you might want to check the anti-freeze level. If it islow it will not heat properly.
Old Oct 21, 2007 | 10:47 PM
helifixer's Avatar
helifixer
Right on Eric as I stated the **** felt hard, finally had a few minutes today pulled the glove box the abs controll and the heater core cover had my wife get her skinny little hands into the duct and found a ballpoint pen. "oops" (mental note clean crap off of dash). anyhow 20 minutes max from start to finish and now a warm truck.
p.s. sent you some love (rep points)
Old Oct 22, 2007 | 08:17 AM
Eric_F250's Avatar
Eric_F250
that's great! glad it worked out for you. i'll defer all credit to whoever i learned that trick from on these forums. saved me a ton of time, money, and cold toes too!
cheers,
eric
