bad problem..
Old Oct 20, 2007 | 12:09 PM
StarTrash's Avatar
StarTrash
bad problem..
ok my 1973 ford 302 just started this...it will rev up to about 3200rpm and then its like its starving for gas but its still going slowly and it pops really bad..like backfireing...i think its the fuel pump what do you all think...it runs fine all the way to 3200...
Ive checked spark plugs..timing..spark wires..disturbor looks good..??
Old Oct 20, 2007 | 12:28 PM
Pickupmanx2's Avatar
Pickupmanx2
Is it backfiring through the carb? That would sound like a timing issue, if it runs just fine and dandy till you start to wind it up, then is goes bad... check your advance, make sure your dist vac advance doesnt drop off.
By the way how is the weather? I am originally from Harrisonville,,,
Old Oct 21, 2007 | 01:19 AM
StarTrash's Avatar
StarTrash
the weather is windy..and thanks im probaly gonna get a new distrubor..thats whats we got it down to..
Old Oct 21, 2007 | 03:56 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
How many miles are on it? Is the fuel filter plugged? Dont waste your money on a new distributor if you dont know for sure that theres something wrong with it.
Old Oct 21, 2007 | 11:25 AM
gnwalker's Avatar
gnwalker
mine did that when the ignition coil went bad
Old Oct 21, 2007 | 04:42 PM
73f100shortbed's Avatar
73f100shortbed
Mine did that when the points went bad. Ran perfect until higher revving than would act like starving for gas.
Old Oct 21, 2007 | 05:30 PM
Mil1ion's Avatar
Mil1ion
Backfiring out the carb is a timing issue.
On another note:
Some people when they do major tune-up work don't put any lube on the distributor cam.. Not lubing this cam will cause the points block to wear down really quick and cause all sorts of ignition problems
Old Oct 21, 2007 | 06:28 PM
StarTrash's Avatar
StarTrash
well its came down to something in the disturbor or something with the igition so im gonna try another coil...and then just a disturbor..
Old Oct 25, 2007 | 12:53 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
:http://www.performancedistributors.com/forddistributor.htm
info@performancedistributors.com
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
