'02 driveline/suspension problem
Old Oct 19, 2007 | 08:44 PM
greg sinapi's Avatar
greg sinapi
Angry '02 driveline/suspension problem
I have had a problem with my '02 since 35,000 mi. The truck now has 100,000 mi(I got the extended warranty). When the truck is at idle, in drive or park, the idle feels rough. Ford says it is ok. When it is driven on smooth roads, the truck has a shimmy, like bad wheel bearings. When it is driven on rough roads, the truck has a shimmy/shudder, at any speed. Feels like the suspension is loose. The truck has new tires, brakes, fuel filter, and alignment. Ford changed the rear axle seals, torque converter, and adjusted the driveline angle. The truck still rides bad like it has done for the last 65,000 mi. Ford does not want to do anymore work until a Ford engineer checks out the truck. Now the warranty has ended(but the repair order is still open), and the transfer case is leaking(unknown if related to my problem). HELP?! I need advice, please........
