Need Help Fast!!asap
Old Oct 19, 2007 | 07:49 PM
ShaneS_09's Avatar
ShaneS_09
I did a plug change on my 90 F150 4.9
I put autolite plugs in reconected everything
I started it up and took if for a spin and it is missing worse than it was before I changed the plugs.
I took it to a friends house he says that the metal thing inside plug wire on cylinder #5 wasnt connecting to the plug.
I got new plug wires cause the wires needed changed anyways.
I started it up and drove it with my friend inside he said to get some injector cleaner in it.
I went to advanced auto with my Bro and on the way It felt like I had NO power whatsoever. I had to have it mashed in 3rd going up a small hill. I got to a stoplight and notice TONS of whitish colored smoke behind me. IT feels like its missing like nuts with NO power. I took it back to my friend and he Took the temp gun to the Exaust.
Back CAT= 352
Front CAT=200something
Back header=497
Front Header=293
He said that he thinks the front Cat is clogged. I need to know that he isnt BSing me or if something is Screwed up. To me it sounds like the CAT is clogged.
Where could I get a new Front CAT?
Old Oct 19, 2007 | 07:57 PM
89frankenford's Avatar
89frankenford
hmm ok before you start replacing the cat/cats what is your temp reading on the dash? or should i say what is the motor running at temp wise? is the check engine light on?. what about replacing the cap and rotor too?
Old Oct 19, 2007 | 07:59 PM
Skandocious's Avatar
Skandocious
Definitely sounds like a clogged cat. You need to shoot the temp gun on both sides of 1 cat and look at the difference between the two numbers. If it is hotter at the rear than it is on the front by more than 10 or 15% then you've got a clogged cat.
Supercouper's Avatar
Supercouper
Double check your wires to make sure they go to the correct cylinder.
Old Oct 19, 2007 | 08:00 PM
89frankenford
to see if your cats are clogged unbolt the y pipe from the manifolds and run the truck and see if it is still lagging power.
Old Oct 19, 2007 | 10:38 PM
ShaneS_09's Avatar
ShaneS_09
I took the flanges off.....unbuckled the pipes. Talk about a PITA those bolt were something! lol. It runs ALot better but its still missing a tad from somewhere so I think the truck might be getting sold. I Know the CAT is clogged though.
I really don't want to buy an new CAT they are EXPENSIVE!!!!!!
SOOO.......are there anyway to UNclog the CAT. I know My Step-dad used CLR and Drain-o to unclog the CAT in the Corvette. Thanks for the REALLY fast reply I needed it.
Old Oct 19, 2007 | 10:51 PM
BEWOLD's Avatar
BEWOLD
does a cat make "tons of whitish colored smoke"? Ive always thought that it usually means burning coolant?
Old Oct 20, 2007 | 08:12 AM
bocephus_3349's Avatar
bocephus_3349
Thats what I thought the signs of a blown head gasket or something along those lines. Have you checked your oil? See if you have any water in there. I could be up in the night. And cats dont cost that much. Just go to summit and you can by a uni one for about 60-100$ that will replace the front and rear cat. Thats what i have to do next month along with long tubes.
Allan Paulley Sr.
1997 - 2003 F150
18
Jan 16, 2015 07:27 AM
Randall's Truck
Jan 20, 2014 02:13 PM
jerem0621
Modular V10 (6.8l)
22
Jul 15, 2012 03:45 PM
MagKarl
Apr 26, 2007 10:39 AM
93_F150
Exhaust Systems
May 2, 2002 01:52 PM
