twin turbos?
Old Oct 19, 2007 | 04:49 PM
solareclpse2000's Avatar
solareclpse2000
twin turbos?
does a twin turbo kit exist for the 2002 7.3 power strokes?
Old Oct 19, 2007 | 05:01 PM
RogueSpear2023's Avatar
RogueSpear2023
Why would you want twin turbo’s? You would be better off with sequential turbo’s, I know sequential turbo’s can be done on a 7.3, but I don't know of a kit for it, most of these have been home made jobs. I think you would be far better off just upgrading the one you have, along with all the other stuff, like HPOP, injectors, fuel pumps, bigger fuel lines. Most of the sequential turbo’s are used in pulling situations anyway, most people are very happy to just upgrade the one they have. Twin turbo’s won't really give more PSI, it's just the either one won't have to work as hard, sequential turbo’s, is where you are going to see the increase in boost.
Old Oct 19, 2007 | 05:22 PM
ron's power stroke's Avatar
ron's power stroke
there not twins..its a compound set up...you can get them here.
http://www.shop.blackwidowdiesel.com...categoryId=126
Old Oct 19, 2007 | 06:16 PM
solareclpse2000
wow those things are freaking SICK! now i want one.lol i have seen some kits but was looking for bolt on like this.jus not sure if i want to spend the money yet.
Old Oct 19, 2007 | 09:49 PM
lukecline's Avatar
lukecline
You need to address your connecting rods before doing twins. Since your truck is an 02 it has powerdered metal rods "PMR's". They will make an early exit if you do too many mods, i would stay away from twin turbos.
Old Oct 19, 2007 | 09:54 PM
RogueSpear2023
I didn't look at what truck he had, lukecline is right your going to have to replace those rods if you want to make serious power. PMR=Crap
Old Oct 19, 2007 | 10:44 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
GOD!!! Why do people always call them TWIN turbos!
Old Oct 19, 2007 | 11:58 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Old Oct 20, 2007 | 12:03 AM
Hiflyer746's Avatar
Hiflyer746
Originally Posted by Tenn01PSD350
hey man that is a sweek cloaking device you have on your rod. how did youdo that? i imagine that is a strong rod
Tim
Old Oct 20, 2007 | 01:13 AM
Tenn01PSD350
That is not my rod, but the forged units are not immune either:
Old Oct 20, 2007 | 02:53 AM
RogueSpear2023
/\ Those bent rods really had to make a mess inside the engine when they went. With enough HP you can destroy anything if not properly equiped to handle it.
Old Oct 20, 2007 | 11:24 AM
solareclpse2000
ouch that looks ugly.i would like to see the block after that one.and STROKEIN IT i use the word twin cuz there is 2 of them.lol
Old Oct 20, 2007 | 12:54 PM
RogueSpear2023
Stokin It, just wants you to use proper terminology, because there is a huge difference between twin turbo, and what diesels use squential or dual turbos. Twin turbos is where each turbo runs one bank of pistons like what is used in most performance gas engines. But because gas engines aren't as strong they can't take the abuse of high boost, unless full blown race engines. So in a twin turbo set-up each turbo has less boost, is usually smaller, so you have less turbo lag. In the dual turbo set-up you get max boost, and still a quick spoot time, but far more boost than with a twin turbo set-up.
Old Oct 20, 2007 | 12:57 PM
glasseater's Avatar
glasseater
wow those pics of rods are starting to worry me...
Old Oct 20, 2007 | 01:12 PM
lukecline's Avatar
lukecline
You have a long way to go before you need to worry about bending your rods . I bent mine @550rwhp on fuel only. They werent bent that bad, but had a definate curve to them.
