3" test cap, any ideas?
Old Oct 19, 2007 | 03:27 PM
smoky_diesel's Avatar
smoky_diesel
Question 3" test cap, any ideas?
I need to find some sort of 3" OD cap or plug for round 3 of my leaky leak tester.
Know of any common plumbing or household plastic/metal items that could be tapped for 1/8NPT?
thanks
Old Oct 19, 2007 | 03:31 PM
bdrummonds's Avatar
bdrummonds
Go to Home Depot, or Lowes. PVC pipe is measured in O.D., not inside diameter. a piece of 3" PVC and a end cap plug. drill and tap and your done.
Old Oct 19, 2007 | 05:08 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Thats right, a 3"pvc/dwv coupling, a 3" cleanout pvc/dwv, a 3" dwv plug.
Or 3" pvc/dwv coupling, 3" X 1/2" reducer with threads on the 1/2" side then use what ever you need to go to the air fitting you need. I would also put a valve inline.
